Other Do I Need A Bigger Psu?
Discussion in 'Hardware' started by splifward, 21 Feb 2012.
  1. splifward
    splifward What's a Dremel?
    21 Feb 2012
    Hello all,
    I've recently made a custom build these are the spec im just wondering if i am going to have to upgrade my 550wat.
    >AMD Phenom II X6 1035T 2.60GHz AM3 Processor
    >ASUS M5A97 AM3+ AMD 970
    >G.SKILL Ripjaws Series 8GB
    >FX Radeon HD 5770 Video Card - 1GB GDDR5
    >SATA Western Digital WD1001FALS Caviar Black Hard Drive 1TB
    >SATA DVD-RW Drive
    this is the psu running it all Ultra LSP550 550-Watt Power Supply, is it enough?lemme know ASAP!! please and thank u all :worried:
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    You should be just fine, adequate for the listed build.
  3. Jipa
    5 Feb 2004
    550 W is plenty, but I have no clue if "Ultra" power supplies are half decent or just plain fire hazards...
  4. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    550w should be fine... just dont overclock to much the deneb cpus are quiet power hungry!
  5. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Aren't Ultra the company who claimed to own the patent on modular cables and were going to sue every PSU manufacturer who was using modular systems?
    If so, I'm pretty sure they're the same as the one that blew up in a CustomPC PSU labs test a few years back.
    It's got 30A on the one 12V rail.
  6. Damenlake
    Damenlake What's a Dremel?
    13 Jan 2012
    550 is fine, unless you are planning on upgrade some of the part later
  7. TheBigFella
    TheBigFella U jelly?
    20 Feb 2012
    Yep, it is good for your configuration, but that PSU is not best quality...
    And as Jakob said do not OC to much, because there is possibility you fry something.
  8. Deders
    Deders Modder
    14 Nov 2010
    Which means it can only supply 360W via the 12v rail, most decent PSU's can provide nearly their entire wattage through the 12v rail if needs be.
  9. Nomaipaker
    Nomaipaker What's a Dremel?
    19 Jan 2012
    Your current PSU would do just fine.
  10. tonpal
    tonpal What's a Dremel?
    27 Jul 2008
    That is an indicator of the age of the design rather than the quality of the PSU.
  11. chrismarkham1982
    chrismarkham1982 Multimodder
    1 Apr 2010
    Yeah, chuck that psu out and get yourself a quality psu.
    David and PingPong like this.
  12. AoE
    AoE What's a Dremel?
    4 Oct 2011
    No way a good quality 450w or basic 500 would power that with plenty of headroom. I have seen someone with a quad core and gtx 550 with a 1050w PSU, I laughed for a week.
  13. Deders
    Deders Modder
    14 Nov 2010
    A quality PSU manufacturer wouldn't use such an old design for a PSU that can be bought today.
  14. tonpal
    27 Jul 2008
    Correct me if I am wrong but I believe we are talking about the OPs existing power supply which may be a number of years old. I didn't see any reference to the age of the PSU. Having said that would probably be wise to play it safe and update to a PSU with a better pedigree.
    Edit: Found an unsubstantiated reference to Andyson as the OEM.
  15. Deders
    Deders Modder
    14 Nov 2010
    I guess only the op can tell us, but I did find it readily available to buy on the web.
  16. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    Existing PSU is suposidly made by ShenZhen RuiSheng Yua . If this is true and i suggest the OP either confirm or not wether this is true but I would not use it with my expensive new PC bits. It might be fine but then again it may very well not.
