Windows Do you use Mouse Acceleration in games?
Discussion in 'Gaming' started by Rofl_Waffle, 25 Mar 2010.
Do you like mouse acceleration?
  1. Yes, I love mouse acceleration
    10 vote(s)
    14.7%
  2. No, I hate mouse acceleration
    58 vote(s)
    85.3%
  1. Krikkit
    21 Jan 2003
    I've used it since forever and I'm totally used to it now. I don't know why you guys hate it so much, a pointing device isn't a natural gesture anyway, so it takes practice to gain precision.
  2. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    It reduces precision by making it harder to translate what your hand is doing to what you expect to happen on screen. I'm sure it's possible to get used to, but it pisses me off no end.
  3. WildThing
    WildThing Minimodder
    26 Jul 2007
    Same here.
    As for the argument that it's not constant, and that it accelerates based on how fast you move the mouse, well I find that useful. You can aim slowly/accurately for sniping, for example, then mouse the mouse really quickly (eg. if you get spotted) to do a 90/180 degree turn and run away. And you don't have to mouse your hand that much.
    However, I must say that for me it depends on the game. For all Source games I have to have mouse acceleration on because it just feels right. Other games may be different. Take Bad Company 2 for instance, I still can't get use the mouse sensitivity on that. Turning acceleration on/off seems to make no difference. I have heard of others experiencing problems with this game though.
  4. Mr Mario
    Mr Mario What's a Dremel?
    4 Oct 2008
    I have always just presumed that's how mouses work, I quite like being able to do large and small movements without having to move the mouse to much. Not sure how I would get on if I turned it off.
  5. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    I can't stand it. My theory on it is that there are two types of people when it comes to cursor pointing: the type who move in a manner that should get there, and the type who move until they are. The former prefer mouse acceleration being off, they prefer a standard translation of hand movement to screen movement so they can consistently judge screen distance and move their hands accordingly. Advantages being the ability to aim at any one point on the screen in a similar amount of time as any other point, disadvantage being that if you miss, or your target moves, you have to either recalculate how far to move, or revert to the latter method which you aren't familiar with. The latter is more for those who think in a "say when" fashion. Your mouse is travelling at whatever speed you feel like and it keeps going indefinitely until your brain says "when" and stops on target. This makes for more fluid aiming and can follow moving targets well. Also, over time you can get used to it and learn to behave like the former method and be a master of all trades. Disadvantage being lower accuracy for farther away points on the screen as acceleration kicks in and less ability for twitch aiming.
    But hey, it's probably nothing like that.
    Krikkit likes this.
  6. Krikkit
    21 Jan 2003
    I think that's a pretty interesting theory there Sloth.
    I reckon it's probably just a mental thing - mouse acceleration is still relatively constant, it's just doing an extra differential instinctively.
  7. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    I don't think it is set to 'on' by default in Windows 7.
    In your start menu, type Mouse, then go to that settings box, then Pointer Options.
    Enhance Pointer Precision is the setting for mouse acceleration (I think), and mine was unticked (having never been altered).
  8. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    I just flick the DPI settings up/down if need be, but I do hate software-controlled acceleration
  9. docodine
    docodine killed a guy once
    10 Feb 2007
    Always had it on, never bothered me. Learned how to play FPSes with it enabled. :eek:
  10. steleet
    steleet Did he death?
    22 Oct 2009
  11. magzarelli
    magzarelli FanMan
    31 Mar 2010
    I play fps games so i dont use it.
  12. Anarki
    Anarki CULV fan
    2 Apr 2010
    I've been playing FPS games for almost 10 years and I always hated it.
    Using it with an operating system is ok, but in games you can never be as accurate as you are without any acceleration imo.
  13. Daytona178
    Daytona178 What's a Dremel?
    1 Apr 2010
    For gaming i prefer using just cheap generic mice...are they not 800dpi?
  14. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    To be honest the statistic is strong enough. I can say nobody likes mouse accerleration.
    Why does all console ports have it and why do some not have a fix for it?
    If you are a game designer and reading this. Please no mouse acceleration for any games ever!!
  15. banshee256
    banshee256 What's a Dremel?
    29 Aug 2005
    I've been away from the 'serious' gaming scene for quite a while now (since UT2004 launched to be exact), but back then, we turned the mouse speed all the way DOWN, not up. Sure, we needed about half a metre of space to move the mouse, but the precision was insane.
    When did this flip? Or were we just wrong and it was all in our heads?
    On topic: I hate mouse acceleration with a passion. Reasons have already been given by others.
  16. knuck
    knuck Hate your face
    25 Jan 2002
    no
    you were right. Consolified games changed that. Nowadays it's all about slow movements and fast mouse
    it sucks tbh
    Vive UT
  17. knuck
    25 Jan 2002
    Okay guys I found a solution for those of you that want to disable it completely in windows 7 :D
    http://donewmouseaccel.blogspot.com/2010/03/markc-windows-7-mouse-acceleration-fix.html
    it works perfectly, as long as you don't change the sensitivity in windows, otherwise it comes back. What I did was just to set the DPI of the mouse to 800 and it's awesome now. I did the ultimate test, aka UT99, and there was no acceleration/mouselag anymore ! It was just like the good old days :D
