Modding Dremel Wannabe
Discussion in 'Modding' started by diabloroker, 6 Jun 2004.
  1. diabloroker
    diabloroker What's a Dremel?
    4 Jun 2004
    okay i just went to this tool place and i bought a thing that looks like a dremel...i hope to cut metal with it. i have to buy metal bids. but first thing before i use it... how do u know if it can cut metal? does it have to be a certain rpm? because mine is 14000 rpm. i need replys ASAP because im going to the tool place again 2marrow and thats when they close.
  2. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    well u can cut metal at any rpm it just depends on the disk ur using, i sugest these uber fiber reinforced disks that are like 3 inches in diameter i found at $4 bucks a pop, it may sound expensive but they dont break or were down like the typical disk,...if not just get reinforced cutting disks pack of 20 for $4 bucks or so. hope i helped and welcome to the forums :thumb:
  3. diabloroker
    4 Jun 2004
    oh thanks....i think i got some of that UBERized discs ur talking about
  4. moddedgeek
    moddedgeek What's a Dremel?
    5 Jun 2004
    otherwise known as fiberglass reinforced cutting disks
  5. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Well not to gloat but 14000rpm is not that great cuz when I cut metal I use highest settings 35000rpm and just barely lean on metal this way the disk dosent breack and the cuts are nice and crisp.
  6. diabloroker
    4 Jun 2004
    i cant really do much about it... dremel and other BRAND names are expensive. and my budget is already used all up.....
  7. toss
    toss What's a Dremel?
    6 Jun 2004
    what are you going to be doing with it? like what sort of metals you cutting?
  8. coil
    coil What's a Dremel?
    25 May 2004
    Related question while we're on the subject: is the simple, single-speed dremel sufficient to any basic cutting I might want to do, or should I shell out for the multi-speed one?
  9. kbn
    kbn What's a Dremel?
    17 Mar 2004
    You should be able to get a decent tool for a lot cheaper. I dont knwo how much dremmels cost in he US but a good one is probably more than £60 here. The one I use cost me £15 (about $25) and works well - apart form it broke yesterday, but thats after a lot of use. A proper dremmel would have broke just the same.
    Mine has 6 speeds, has a 140w motor, and i think it does something like 32000rpm
