Drive error in My Computer
Discussion in 'Tech Support' started by hydro_electric_655, 20 Jan 2008.
  1. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I had an old fried DVD burner (this was when DVD burners were a new thing) so I replaced it, the new DVD burner works, but I am having some issues. It seems to burn fine, but when I try to access the drive (CD contents) through my computer, I get an error message
    D:/ not accessible
    Incorrect function.
    Works fine when exploring CD's with stuff on them, but I can't access the CD or DVD through My Computer, external programs can burn to them but it tends to come up short and not work quite right, the old DVD gave similar errors, but didn't even get to the point where it registered blank media.
    I have no idea what to do.
  2. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
  3. hydro_electric_655
    13 Jul 2006
    I should have mentioned i am using windows XP, and a Pioneer DVR-2810, but the think looks promising.
    It still is acting the same way, Nero software recognizes the disk and the data on it, but my computer is useless. I followed the steps and did everything, I'm not sure what the deal is.
  4. who cares
    who cares What's a Dremel?
    20 Jan 2008
    Hi my first post so hope this helps, double click my computer, right click optical drive in question select properties from drop down menu, new window will open up, click recording tab, and select enable recording on this drive.
  5. hydro_electric_655
    13 Jul 2006
    I found no recording tab in properties. XP SP2.
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    That's very strange - 'coz all writers should have that tab :confused:
    What tabs have you got along the top then?
  7. DougEdey
    5 Jul 2005
    Does XP recognise it as the correct model? If so, then it's probably a fault with the cable, if not, then probably a fault with the drive.
  8. hydro_electric_655
    13 Jul 2006
    It registers as a Pioneer DVD-RW DVR-212D SCSI CdRom Device, and it's a Pioneer DVR-2810, so what shall I do? Return the drive as defective?
  9. DougEdey
    5 Jul 2005
    Sounds like it's got the wrong firmware or you've been sent the wrong drive. Return it to the retailer.
  10. ryanjleng
    ryanjleng ...
    15 Nov 2007
    check firmware update page.
  11. hydro_electric_655
    13 Jul 2006
    I stand corrected, DVR-2810 is the package (Nero + Pioneer DVR212) package name. I'll check for firmware updates now, but I think this is a windows problem rather than a hardware or connector problem.
    I'm still confused though?
  12. hydro_electric_655
    13 Jul 2006
    It has the latest firmware...
  13. hydro_electric_655
    13 Jul 2006
  14. SinxarKnights
    21 Jan 2007
    You defiantly got me stumped. If you can try it in another computer please do so. Otherwise, if it was me, I would get an exchange.
  15. hydro_electric_655
    13 Jul 2006
    I don't have another PC, but I am fairly sure this is a Windows problem and not a drive problem. I'm stumped too.
  16. ToMMo
    ToMMo What's a Dremel?
    5 Dec 2007
    don't know if it's possible for CD drives but can you go into task manager and uninstall it, then let windows re-install the drivers?
  17. hydro_electric_655
    13 Jul 2006
    Tried that already, didn't do anything.
