Windows Driver issue causing lockup, I think...
Discussion in 'Tech Support' started by PeteA, 9 Mar 2014.
  1. PeteA
    PeteA What's a Dremel?
    22 Jun 2013
    System -
    Z68 Fatal1ty Pro Gen 3
    Intel 3.2GHz (Ivy Bridge)
    8GB Corsair Vengeance DDR3-1866Mhz
    Asus HD6770 x 2
    History -
    Got handed this as it was dead after being put together... Nice easy fix by dropping in a Celeron 2.4GHz CPU so I could update the bios to 2.10 so it recognized the Ivy Bridge and loaded win7 as asked... And gave it back. :thumb:
    Issue -
    Seems to have a driver conflict causing it to lock-up when using the onboard Ethernet, which I thought I'd found the problem... onboard sound drivers as it works fine when in safe mode with networking enabled. :idea:
    Tried various combinations of drivers etc to try and fix it but it's beat me, anyone come across this and have the solution? :wallbash:
  2. PeteA
    22 Jun 2013
    Disabled everything I could (onboard audio/vga/hdmi/1394/2nd LAN Socket) etc... Which left me with one working LAN socket and it's still locking up/freezing except in safe mode!?! :wallbash:
    I just don't get it... what the hell am I missing... Any help/idea's appreciated!! :confused:
    Something stupid more than likely, knowing me!?! :sigh:
  3. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    With the change of hardware and lots of drivers installed becoming a bit of a mess mite be a good idea to do a fresh install? or at least test it with a USB bootable Linux to make sure its not the hardware.
  4. PeteA
    22 Jun 2013
    Appreciate the reply and advice...
    I through in the towel earlier today and wiped it clean and will start a fresh when I have a whole day to sit at it, will be checking everything as I go this time to see if I can pinpoint the cause if/when it happens. :thumb:
