Graphics Driver to bypass onboard audio decoder on AIW 9000
Discussion in 'Hardware' started by star882, 9 Dec 2005.
  1. star882
    star882 What's a Dremel?
    19 Mar 2003
    Is there a driver that allows me to use my sound card to decode audio from an AIW 9000? My sound card doesn't have a S/PDIF input and I want surround sound.
    The system runs Windows Server 2003, BTW.
    EDIT: I couldn't stand the analog output of my particular motherboard, so I bought a Sound Blaster Live 24 bit. Now, S/PDIF input is possible, but I'll need an adapter if I go that route. Therefore, I'd prefer a software method.
  2. vts
    vts What's a Dremel?
    20 Oct 2005
    can you not just disable the aiw driver in device manager, thereby it routing the audio out of your sblive, or even change the sound options in windows control panel to only use default hardware, and change the sblive to the default?
    just a thought
