Reviews Drobo 5N2 Review
Discussion in 'Article Discussion' started by bit-tech, 17 Jan 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. dolphin-promotions
    dolphin-promotions What's a Dremel?
    12 May 2009
    Everyone on /datahoarder hates Drobo for its BeyondRAID filesystem. If the Drobo dies, you're screwed apparently
  3. jb0
    jb0 Minimodder
    8 Apr 2012
    "soul download manager"
    Satan's own NAS box?
  4. Zak33
    Zak33 Staff Lover of bit-tech Administrator
    12 Jun 2017
    Everyone? really?
    I am sure I had it done for a mate.... not long ago....and frankly I'm rubbish at that stuff,.
    Will try to find the email.....
  5. Zak33
    12 Jun 2017
    lol... Anthony will spank himself for you on that one I assure you.
    His "soul" will be swallowing in it's dictionary within hours ;)
  6. Zak33
    12 Jun 2017
    Drive Savers did it... but I'm not posting a link cos I'll not advertise for them. But it is do-able
  7. Yaka
    Yaka Multimodder
    26 Jun 2005
    can vouch for this drobo support generally insist you buy a new drobo to try and solve your problems. ive had crap luck with em used to own the orignal 8bay nas. my dad however had the 2nd gen 8 bay nas and he had no problems but having seen my probs with drobo support he switched to a synology nas instead
  8. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    That was my understanding with Drobo - if the Drobo unit fails, it's a case of get another one, move all the drives across at the same time then powerup the new one so it can find the existing drives and get up and running again. So far my Drobo S has been holding up well for media storage, it's very loud and not really ideal but the simplicity of their redundancy system was too good to overlook (as it predated Storage Spaces as used in Windows 8/10). It's annoying that getting the unit repaired if it fails is pretty much out and having to drop another £3-400 for a replacement unit to keep my data doesn't thrill me either, mainly thanks to their propriety system.
    The main issue is that the software allows you to set up an initial storage pool but it appears to be a hard cap - my Drobo S (purchased August 2012) is maxxed out at 4x4TB drives and I couldn't make a pool bigger than 16TB with 1 HDD for redundancy - if I move my drives to a newer unit, my understanding is that the existing pool is still stuck at 16TB unless I start over.
    It also takes forever to replace a drive - doing so on my Drobo, it takes about 24 hours for it to shuffle data around before it's back in protection mode.
Tags: Add Tags
