Dual channel memory on nf-7
Discussion in 'Hardware' started by Anator, 17 May 2004.
  1. Anator
    Anator What's a Dremel?
    26 Feb 2004
    Simple question, which slots do i have to use to use dual channel memory?
    Theres 2 slots together and then 1 seperate.
    Cheers
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    The seperate slot and any of the others please carol :worried: :p
    Serioulsy, 1 in the seperate then stick one in one of the others :D
  3. Endre
    Endre What's a Dremel?
    18 Mar 2004
    That's correct, 1+2 or 1+3. 1+2 gives me 1 MHz more than 1+3. :D
  4. mushky
    mushky gimme snails
    24 Mar 2003
    can you put a 512 stick in the seperate slot, and 2 x 256 sticks in the other two, and run it in dual channel still?
  5. Highland3r
    25 Jul 2003
    IIRC yes, there was a thread on this not long ago.... It runs in DC, but not sure if one of the sticks runs in single channel???? :confused: :confused:
    <edit> discussion was over at Overclockers, not here...... heres the thread http://www.ocforums.com/showthread.php?s=&threadid=296537</edit>
  6. tongue_of_colicab
    tongue_of_colicab What's a Dremel?
    14 May 2004
    DC works aslong as you use 2 the same sticks in the right slots if you add a third it wont run in DC anymore since ur pc now has to work with 3 sticks so if it would still use dc on those 2 sticks than wverything will get messed up since the third stick laggs behind and all stuff that doesnt makes it work guess you have to wait for tripplechannel for that ;) Butsome intel boards that have 4 mem slots can work in dc if you put in 4 sticks with the same size.
    btw dc will never work with sticks of different sizes
  7. Anator
    26 Feb 2004
    working now thanks all
  8. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Breath goddammit! :hehe:
  9. fivecheebs
    19 Feb 2003
    whoops! (dunno how that happened!) please delete this post
