Electronics Dual Core CPU usage meter... how?
Discussion in 'Modding' started by '99, 3 Feb 2008.
  1. '99
    '99 What's a Dremel?
    5 Jan 2004
    Hi
    I was wondering if it is possible to build a CPU usage meter, for a Core 2 Duo CPU.... Using 2 tri-color LED's?
  2. ch424
    ch424 Design Warrior
    26 May 2004
    Yes, it is possible. Do you know what a microcontoller is?
  3. '99
    5 Jan 2004
    I'm not that hardcore at electronics. But if you got a link... and maybe a diagram, I know someone that could help me out. In my other rig I use the CF635 lcd panel, the one with 4 LED's and keypad..., but I dont have the room for it in the new one.
  4. Acksaw
    Acksaw What's a Dremel?
    7 Jan 2008
    Make sure you keep us updated on this!
  5. ch424
    26 May 2004
    You need to program a microcontroller to connect to your serial or USB port, and control the LED brightnesses using PWM, depending on what value the computer sends the microcontoller over serial/USB. You also need to find/write the software on the computer to grab the value of CPU usage and send it over serial/USB.
  6. ch424
    26 May 2004
