Networks Dual network connection problems.
Discussion in 'Hardware' started by ukmaxx, 11 Oct 2007.
  1. ukmaxx
    ukmaxx What's a Dremel?
    8 Feb 2007
    Hi all.
    I recently added an additional network card to my work pc. i need 1 connection to the net and 1 to a machine at work. The original network connection works ok with either cables i plug in, but which ever one i plug in to the new card works for a few seconds and then says limited connection.
    Thanks, Adam.
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Does it work if a cable is only plugged in to the new one?
    Is it even receiving an ip address?
