Dual P3s
Discussion in 'Hardware' started by severedhead, 22 Jul 2005.
  1. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Quick and easy, do I need a matched pair of P3s to run in a dual board or would any two behave themselves providing they are the same speed etc?
    Also, can I use 2 slockets in a dual board without problems?
  2. phuzz
    phuzz This is a title
    28 May 2004
    I don't know about p3's specifically, but with the newer Xeons, the motherboard generally seems to be upset unless the chips have the same stepping code (last few letters of the serial number, or on the bottom of a Xeon, not sure where on a P3). Although it should work with a certain range of steppings, I've never seen it happen,
    So, unless you can get a cheap deal, go for matched. It'll be less potential hassle.
  3. severedhead
    19 Dec 2002
    Will bear that in mind, thanks. Its just that 1GHz P3s are far more common on eBay seperately as opposed to a matched pair.
  4. phuzz
    28 May 2004
    If there's lots avaliable, you might be able to find two that match...Or you could just buy loads and mix and match till you find a pair that work... ;)
  5. Skylined
    Skylined Minimodder
    3 May 2003
    Careful with the mobos.
    The PIII era had faulty mobos with faulty capacitors.
  6. severedhead
    19 Dec 2002
    I notice that some people list the stepping too, gonna try find a few the same and see what happens. Can always sell them again.
    Thanks for the warning, but I already have a mobo thats been running a couple of 450s for a while now. Tis just a bit slow and needs an upgrade.
