A/V dual sound
Discussion in 'Hardware' started by crushersc934, 2 Jun 2007.
  1. crushersc934
    crushersc934 What's a Dremel?
    24 Dec 2006
    ok i dont know if this is the right section or not. but i have a Plantronics BT headset and i want to use it for just vent both incoming and out going and have my normal speakers for the other sounds. is that possible. if so can someone pls tell me how :clap:
  2. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Phone, PDA, Computer.
    What type, OS, etc
  3. crushersc934
    24 Dec 2006
    it is on a PC, i would of hoped you knida thought that since i said vent(ventrilo), XP home (OS)
  4. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    yeah we're not walking product inventories. most of us don't know what the hell a 'vent', or even a 'ventrillo', is. and you didn't state XP in your first post. please read what you write and be more clear if you expect help.
    i don't even know why i bothered, considering your apparent expectation for us to divine your desires and then cater to your every whim, but it appears ventrilo has a support forum - http://www.ventrilo.com/forums/
    you are probably better off asking them to help. i sure as hell ain't going to bother further than this.
  5. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    ahahahah, i'm not clear on what you mean.
    And Omg your humour is as amazing as your photography, and photography is good!
  6. gar
    gar Minimodder
    15 Sep 2004
    Yes, what on earth is a vent? I mean, I'm big into av and I've not yet heard of this one! (Noting this is the AV thread)
  7. Cardan
    Cardan What's a Dremel?
    21 Jun 2005
    look through the settings on vent. im pretty sure you can change what the indbound and outbound sources are
