A/V DV capture goes checkers!!!
Discussion in 'Hardware' started by Bust_A_Cap, 16 Jan 2005.
  1. Bust_A_Cap
    Bust_A_Cap What's a Dremel?
    22 Dec 2003
    Aight well i FINALLy got my computer up and running, and now it is a sort of video editing/playing station. I'm using a Firewire IEEE 1394A card to interface between the camera and the computer. I'm using Adobe Premier to edit the videos. So first off i just took some random footage of some stuff and tried to capture it. I ran into a problem though. When i captured the video and played it back the video would have a checkerboard effect sometimes. Like certain pixels were glitching or something. Any ideas on what caused this or how i could fix it?
    Thank you!!!
  2. djtitan
    djtitan What's a Dremel?
    18 Aug 2004
    sounds like droped frames in the feed. How fast is your system, mainly, how fast can you write to your hard-drives?
  3. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Sorry I have no idea about this but just a stab in the dark ...
    Signal Degradeability ?
  4. djtitan
    18 Aug 2004
    I have done some checking and it seems that sometimes premiere can have some capture problems. Try using a different capture program. My personal favorite is WINDV.
  5. Mortus
    Mortus What's a Dremel?
    30 Sep 2004
    I use pinnacle studio 9 and its pretty cool, i use adobe at work and its not that great at capturing the files :(
