Other Dyson Airblade waste water
Discussion in 'General' started by Cupboard, 24 May 2009.
  1. Krikkit
    21 Jan 2003
    Technically impossible, but interesting manxminkx. :p
    Tbh I don't want to have to wear ear defenders while benchmarking. I'll just buy LN2.
  2. DougEdey
    5 Jul 2005
    Mental note to invest in medical supplies for LN2 damage
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I've never used one but they look pretty dam cool
  4. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Having your hands dried by 400mph winds is impressive.
  5. DougEdey
    5 Jul 2005
    Pfft, I get 450mph easy out my arse
  6. Da_Rude_Baboon
    28 Mar 2002
    So you have your arse out in public toilets so man can dry their hands in your butt crack then? :p:lol:
  7. DougEdey
    5 Jul 2005
    Not in public ones, just private.
  8. Krikkit
    21 Jan 2003
    Where can I subscribe?
  9. DougEdey
    5 Jul 2005
    If you have to ask you aren't allowed to know, invite only
  10. Nexxo
    23 Oct 2001
    I always suspected you were full of hot air. :p
  11. Nexxo
    23 Oct 2001
    No, damn cool are the full-body warm air blow dryers by Triton that mount in the ceiling. Have a shower, then just stand under it and presto.
  12. talladega
    talladega I'm Squidward
    18 Aug 2007
    Open registrations any time soon?
  13. DougEdey
    5 Jul 2005
    Sorry, long term Beta, need full Medical Clearance before we go to RC
  14. remixme
    remixme Own a Dremel, but not used it yet!
    11 Aug 2008
    Dyson Airblades are awesome, getting increasingly popular.
    They have only one drawback......
    You can't use them to dry your crotch after the ridiculously high water pressure taps splash you.
  15. swoop
    swoop What's a Dremel?
    10 Jun 2010
    "What happens to the waste water?" -IT GOES ALL OVER THE FLOOR! Just had a Dyson Airblade installed in our workplace. It works pretty well if you move your hands up and down (as per label instruction) but the water has no where to go. In a conventional dryer a percentage of the water is evaporated as you wring your hands, also the down-draft tends to dry any drips off the floor. Neither of these things can happen with the Dyson, so you get a safety hazard puddle to slip on. The earlier Dyson had some sort of a 'bung' in the bottom groove but the latest ones have dispensed with it. I think Dyson are aware of the problem.
    As a friend of mine commented "He should of kept to sucking, not blowing"!
  16. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    You mean that you're not so paranoid about random water pressure in public places that you turn all taps on at arms length? Lucky you. :D
  17. flapjackboy
    flapjackboy What's a Dremel?
    24 Apr 2009
    Probably be a smaller version of
  18. The_Beast
    21 Apr 2007
    ^^^ that only cost a couple of thousands of dollars
    totally worth it
  19. kenco_uk
    28 Nov 2003
    I wonder if you put a load (50 or more) really close together, would the balloon travel so fast it turned into a cheesecake?
  20. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Awesome video, the nerds dominos :)
