News EFF unveils Let's Encrypt HTTPS programme
Discussion in 'Article Discussion' started by Gareth Halfacree, 19 Nov 2014.
  1. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    Sales maybe going up, not really surprising, but it seems that there are very few commercially available encryption products that have not been compromised.
    Probably best not to tell your customers about that ;)
    www.theguardian.com
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    Except of course the customers of vpn services are under surveillance from the very moment they even consider using one...
    https://daserste.ndr.de/panorama/aktuell/nsa230_page-1.html
  3. adam_bagpuss
    24 Apr 2009
    personally its a bad ideal to use a VPN service as you are not in control of the the VPN connection or encryption keys. business that are serious about protecting data would use there own and offload the keys
    well i hope you dont bank online or use itunes or buy from amazon. I take the the above with a pinch of salt and mealy suggests not confirms with proof that these relationships exist and that backdoors are built in to products.
    I did see mention of many services for VPN which are known and again most likely down to the fact the NSA or GCHQ hold the master key after obtaining legally or illegally from said company
    It hard to obtain a key when its sat in a box that can only be accessed using 2FA locally.
    It also mentioned brute forcing using super computers which i guess ultimately is possible
    i guess overall long story short - nothing is 100% but making it as close to 100% as possible is preferable.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    And keep your fingers crossed that no one has brokered a deal with the manufacturer of the box to insert any weaknesses, or other exploits. :worried:
  5. exceededgoku
    exceededgoku What's a Dremel?
    19 Oct 2006
    If it takes you 2-3 hours to install an SSL certificate you should not be hosting a 'secure' website.
  6. Bionic-Blob
    Bionic-Blob What's a Dremel?
    2 Aug 2007
    It's referring to the time taken to obtain the certificate, not install it.
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    And if that fails they simply drop some spyware on your system, doesn't really matter then if they have access to the encryption you use for your communication.
