Cooling ENTHOO EVOLV ITX: CPU cooler and fans
Discussion in 'Hardware' started by silk186, 6 Jun 2019.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I will be moving my computer into a Phanteks Evolv ITX Mini-ITX Case and I'm looking for advice on cooling.
    I want the computer to run cool and stable while gaming and I want it to run quiet, preferably silent during light loads.
    CPU cooler:
    the Noctua NH-L9i is struggling with gaming right now.
    CPU clearance is 200mm
    What are some good options, would be more than happy to buy used.
    Fans:
    The case comes with one 120mm but is missing the front 200mm fan.
    The case can hold up to 5 fans.
    I want to get the fans right before I put everything together but don't want to waste money.
    I do have a Cooler Master 200mm RED LED that I can use, are these any good?
    Front: 2x 120mm/140mm or 1x 200mmm
    Read: 120mm or 140mm
  2. RedFlames
    23 Apr 2009
    NH-U12A if you can afford it, one of the other noctuas if you can't... even the hulking D15 should fit.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    As above, if you buy a Noctua NH-U12A you will probably never have to buy another air cooler again.
    Pricey but as the review on bit-tech says, it embarasses everything else with its quality and performance. It even beats AIO coolers.
    An alternative is to buy @kosch 's BNIB Corsair H60 AIO for £48 in the marketplace?
    https://forums.bit-tech.net/index.p...l-amd-liquid-cpu-cooler-cw-9060036-ww.362186/
    Another alternative is the BeQuiet Dark Rock Slim with is half the price of the Noctua?
  4. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    The biggest noctua you can fit. They truly make great products.
  5. silk186
    silk186 Derp
    1 Dec 2014
    They NH-U12A is a marvel of engineering but the price is way over budget for my build.
    Case: shipping
    CPU/MB/Memory/Cooler - £270
    12tb storage - £105
    Monitor - £270
    500GB NMVe - £90
    RX 480x 8GB- £110
    That last cooler I bought was a Hyper 212+
    I want something that will perform well with a moderate overclock.
    I did see @kosch 's Corsair H60 AIO for £48 but I wasn't sure if I wanted/needed to pay that much.
    Is it a good value for performance given my build?
    Do many used coolers go on the marketplace?
    The Noctua NH-U12S and Noctua NH-U14S are £53 and £56.
    I would prefer to go around £30-40 if possible.
    I can't find any comparisons between the Noctua NH-U14S and the Corsair H60 (2018).
  6. Fingers66
    30 Apr 2010
    According to a Hexus review here, the NH-U12A and the NH-U14S are very close (within 1C) in performance (8700K).
    According to a TechPowerUp review here, a CoolerMaster Hyper 212X is 7C behind the NH-U12A under load (8700K).
    If you can't afford to spring for a high quality Noctua or even a BeQuiet, go for the CoolerMaster at under £30 because it will at least cool your 6700K better than the NH-L9i will - even Noctua's CPU compatibility listing says that the NH-L9i should only be used on a 6700K with a good ventilation case (i.e. more intake fans than you have).
    If it was me, I would try the 200mm front fan first and see the result, it won't cost you anything. If you have a couple of 120mm or 140mm fans then it is worth trying those in the front as well for comparison. Make sure you have at least one 120mm/140mm exhaust fan as well as there is no point in loads of air intake if the hot air stays in the case. With you running an RX480 there will be a lot of hot air in the case to get rid of.
    Edit: again it it was me, my ideal setup in your case would be something along the lines of 2 x 120mm/140mm intakes with a single 120mm/140mm exhaust and whatever you like for a CPU cooler. My own ITX rig is 2 x 140mm PWM fans as intake with 2 x 120mm Noctua PWM fans as push/pull exhaust on a Corsair H55, cooling an i5 8400 in a Fractal Nano S case. Temperatures are really cool but the biggest thing for me is the silence, I sometimes can't tell if the PC is actually running - but note that I am not running a GPU in my main rig.
    adidan and Arboreal like this.
  7. adidan
    25 Mar 2009
    I've found this to be the best setup, along with whatever the PSU exhausts the 92mm fan on my cheapo cooler I bought to tide me over in NZ still keeps my 3770 in the 60s in a matx case.
