"Error Disabling Connection- It is not possible to disable the connection.. help?
Discussion in 'Tech Support' started by LightingBird, 19 Aug 2006.
  1. LightingBird
    LightingBird Minimodder
    25 Feb 2004
    Ok out of nowhere I'm getting this problem. I go into network connections, then I try to disable my lan connection and enable my wireless and bamm...
    "Error Disabling Connection- It is not possible to disable the connection at this time. This connection may have one or more protocals that do not support Plug-and-Play"
    What the heck?
    I've tried a scan on my antivirus software - failed
    Ran adaware - failed
    Disabled uPnP - failed
    I can disable either in the device manager but anytime I tried to enable the wireless I get a "connection failed".
    Any help?
  2. LightingBird
    25 Feb 2004
    I'm still having this problem. Can anyone help?
  3. DougEdey
    5 Jul 2005
    Useful information would be required such as:
    Hardware, driver version, operating system and so on.
  4. krimson
    krimson What's a Dremel?
    16 Nov 2006
    do you have the correct drivers installed?
    do you have the correct settings on them (like, they dont both have the same ip, or something like that)
    are there any resource conflics? (right click my computer > properties > hardware > device manager) any red Xs, or yellow !s or anything like that?
    bios update?
    try reinstalling/updating the drivers for each device, you can even use the device manager, and remove/uninstall the device, and then reboot, and windows should re-find them..
  5. Andersen
    Andersen Morally questionable and ethically wiggly
    25 Nov 2002
    Send a Hijackthis log to anders3n -at- gmail.com and I'll have a look at it.
  6. LightingBird
    25 Feb 2004
    Windows xp
    Compaq 601c
    It was working fine. I could disable it left and right. All the drivers are fine. It just suddenly would not allow a disable.
