Case Mod - Complete Evangelion Mod =w4rb0y=
Discussion in 'Project Logs' started by warboy, 11 Sep 2018.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    Hello to all,
    I hope you rested a little bit in August.
    Ready to start again with new mods?
    I'm assembling a PC inspired by the Neon Genesis Evangelion series.
    I thank immensely thank you who helped me!
    Hardware:
    Case:
    HYDRA NR01
    Motherboard:
    X299 AORUS GAMING 3
    CPU:
    Intel Core i5-7640X
    VGA:
    MSI GTX980 GAMING
    RAM:
    32GB S3+ DIMM DDR4 2400MHz C17 (4x8 Gb) https://s3plus.com/it/products/dram/desktop/s3-dimm-ddr4-2400mhz-c17-4gb/
    SSD:S3 PLUS TECHNOLOGIES 480 GB SSD X2 https://s3plus.com/it/products/ssd/consumer/ssd-sata-3-0/
    POWER SUPPLY: FOCUS PLUS 750 Platinum FOCUS Plus 750 Platinum - Sea Sonic
    SSD M.2: XPG GAMMIX S10 PCIe Gen3x4 M.2 2280
    HD : WD 1 TB
    Liquid Cooling: Thermaltake
    2x Radiator: Thermaltake Pacific RL140 Radiator
    Radiator fans: 2x Thermaltake Riing 14 RGB Radiator Fan TT Premium Edition
    Reservoir: Thermaltake Pacific R33
    2 x pump: Thermaltake Pacific P1 Black D5 Pump w/ Silent Kit
    Final pics :
    _Prometheus_ and Dot_Kappa like this.
  2. warboy
    24 Nov 2011
    For those who do not know, I present you the case HYDRA NR01
  3. warboy
    24 Nov 2011
  4. warboy
    24 Nov 2011
  5. warboy
    24 Nov 2011
    Now some photos of the Power supply FOCUS PLUS 750 Platinum
  6. warboy
    24 Nov 2011
  7. warboy
    24 Nov 2011
  8. warboy
    24 Nov 2011
    now passes to the action with the airbrush on case Hydra NR01
    I used the colors Createx and Wicked colors for aerography.
    The airbrush used for this aerography is iwata HP-CR 0.2
    Watch the video ;)
    _Prometheus_ likes this.
  9. warboy
    24 Nov 2011
    Even the power supply has been customized.
    watch the video ;)
  10. warboy
    24 Nov 2011
    To mount the two pumps (Thermaltake Pacific P1 Black D5 Pump w/ Silent Kit), I created an inclined aluminum support
    _Prometheus_ and kim like this.
  11. kim
    kim hardware addict
    10 Jan 2016
    :clap: you're really talented with airbrushing....love the mod too, the pumps placement and the inclined support, great work so far :thumb:
  12. Cheapskate
    13 May 2007
    Looks awesome. :D Great airbrush work, as usual.
  13. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Cheaps is right ! great brushwork second to none :rock: The whole mod is looking very current and on point :dremel::dremel:
  14. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Well done Warboy :clap:
    Mecha theme with the choices you made with hard tubes, yellow liquid and lights...simply rocks :thumb:
  15. warboy
    24 Nov 2011
    Thanks guys! ;)
  16. Mopsi
    Mopsi What's a Dremel?
    12 May 2017
    I just love the paint job and the short video showing how you made it. Great technique!
    warboy likes this.
  17. warboy
    24 Nov 2011
    some pics of Motherboard: X299 AORUS GAMING 3
  18. Mopsi
    12 May 2017
    Really nice job on the airbrush.
  19. warboy
    24 Nov 2011
    Thanks Bro!!
