This is my first post in this forum and hopefully my first scratch build to actually finish. EVENT HORIZON The build is inspired by the Black Hole shown in the movie Interstellar and the goal is to build it as low budget as possible. Components what I have currently: Gigabyte b450i aorus pro wifi Ryzen 5 1600 Team Tforce Delta RGB 2x8gb 2666mhz ram Sapphire Pulse Vega 56 cheap PCIE riser future components: FSP flexguru 500w - cheap and locally available flex psu I can get CM G200P or ID-Cooling IS-50x - low profile cooler that can do rgb 2 ARGB fans - if price would not be a problem in the future Corsair fans would be the best option, 2nd option is using Cooler Master's ARGB LED controller Renders: Renders from Fusion 360 and components are not same with what I have. -with Low Profile Cooler -with Wraith Spire
Sorry, images from imgur spits out error whenever I save it. Switched with a different image hosting now.
