Case Mod - Complete ⭐ EVIL MASTER - CMWS 2019
Discussion in 'Project Logs' started by pccustom, 3 Oct 2019.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    HERE My project EVIL MASTER
    this project is made for an amazing light effects
  2. pccustom
    12 Jul 2017
  3. pccustom
    12 Jul 2017
    psu cover building with a little windows with psu and graphic card logos
    this is an support to keep cover psu very firm on te chassis
    in this way the psu cover will be firmly supported as the majority of them.
    over time I realized that it needed to be changed into a led panel below
    now is better!
  4. pccustom
    12 Jul 2017
  5. pccustom
    12 Jul 2017
    Posted September 18 (edited)
    these are the LED covers for the SSD
    technical tests for positioning
    I wanted to place LEDs under the PSU cover but because of the space it is not possible then I have persuaded myself to make a back plate I hope it is good ...
    I used two lilac diapers, one of 4 mm for the underlying paste and one of 2 mm for the upper part
    I also decided to change the front panel, coolermaster is fantastic, it already has its LEDs assembled together with the case, I change the handle to create a new one
    completion of the bulkhead logo
    these are the supports to fix the internal led panel that also supports the ssd
    there is plenty of space for cables
    arduum likes this.
  6. pccustom
    12 Jul 2017
    I decided to add a back plate for the GPU but without covering it completely, this fantastic inno3d card already has LEDs and I don't want to hide them
    the surface is very wide, I can put the leds only in the upper part to use all the light I can use the white vinyl below to maximize light refraction
  7. pccustom
    12 Jul 2017
    comes the most boring part .... place all the leds strips, the cables must not be seen below, so I will make them pass under hard work but the final effect will be beautiful.
    Edited September 25 by MAYHEM MODZ
  8. pccustom
    12 Jul 2017
    this case there is no liquid system AIO I have to modify the case, the grids would greatly limit the flow of air, I prefer to open it.
    Edited September 25 by MAYHEM MODZ​
  9. pccustom
    12 Jul 2017
    I proceed with another, the LED pan for the ssd
    use of the adhesive to stick together the 2 pieces of acrylic
  10. pccustom
    12 Jul 2017
    another change not decided at the beginning, I decided to change the feet by removing the original handles and making LED feet, they are basically small boxes with an aluminum frame with strips inside them
    I have no mechanical means all the work is done by hand, and I take the measurements little by little to make mistakes.
  11. pccustom
    12 Jul 2017
  12. pccustom
    12 Jul 2017
    I first fixed the upper frame of the legs and used the holes already present in the case and their screws,
    in the lower frame I put a LED screen
    I made other holes to pass the 12v electrical cases, and then I fixed the small acrylic panels in acrylic and at the end the piece of the aluminum frame at the base where I placed the LEDs, the work was really hard and it took me 2 days to make them but it was worth it the effect I really like.
  13. pccustom
    12 Jul 2017
    ow is time to assembling
    setting RAM and GPU RGB ..
    shoting time..​
  14. pccustom
    12 Jul 2017
  15. pccustom
    12 Jul 2017
    FINALS photos
    so evil so lovely....
    a very special trank sto my sponsors
    INNO3D, SEASONIC, CRUCIAL, ASROCK, DEEPCOOL. HWLEGEND FORUM
  16. pccustom
    12 Jul 2017
  17. pccustom
    12 Jul 2017
    here the final video
  18. Yury
    Yury What's a Dremel?
    7 Mar 2019
    Red, red, congratulations
  19. RedWolfwere
    RedWolfwere What's a Dremel?
    1 May 2011
    Bello bello bello!
    Bravo!
  20. pccustom
    12 Jul 2017
    grazie!!
