"Experimental-Lambda-Core" HL² Mod
Discussion in 'Project Logs' started by *Butterkneter*, 18 Aug 2004.
  1. *Butterkneter*
    *Butterkneter* What's a Dremel?
    18 Aug 2004
    Butterkneter's "BLACK MESA EXPERIMENTAL LAMBDA CORE"
    Already testet on a LANSession with 1224 Gamers. It worked !!!
    (sorry for my terrible english)
    After many hours of work now its almost done ( 99%). Inspired by the phantastic work of Piloux, I also decided to build a HL² Mod.
    System: Gehäuse - Chieftec CS 901 Server TowerMainboard
    Gigabyte GA - 7VRXP
    1 GB DD Ram PC 2100
    Netzteil 530 Watt
    Sapphire Atlantis Radeon 9700 Pro
    Soundblaster Audigy Gamer
    1 Nec DVD-Burner, 1 x DVD
    4 Harddisks = 280 GB 7200 rpm
    L O G :
    At the Beginnig I used Sketchup to help me imagine how it would look like. . .
    The Layout of the frontdoor . . . .
    First a little Shoppingtour
    Here what i found in a little turkish store . . .
    Some Base Painting of the Interior . . .
    First Tests with the Rustpainting
    here on with Polystyrol. My favourit material
    here on some other built- in- elements
    The Frontdoor . . .
    DVD-RW and DVD
    the 120 mm Fan
    the exterior Fan (80mm) with LED Lights.
    The Reactor-Core . . .
    The Rustpainting for the TFT an the keyboard
    the side-doors of the CS 901 without . . .
    the side-doors of the CS 901 with Rust . . .
    First Test of the layout for the Frontpanel
    The Result
    With Killswitch , Keyswitch, Cigaretlighter
    All together it looks like this . . .
    to be continued . . .
    Butterkneter
  2. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    That´s some awesome work.. the HL2-theme has been kind of overdone by now, but whatta heck that case is just top notch! :D
  3. crash32953295@msn.
    crash32953295@msn. What's a Dremel?
    2 Aug 2004
    i couldnt care less how many people do the ideas as long as new ideas are made and i love some of the modding in this, one question how do u do the rust affect and/or do you know how to do a burnt or cindered look, this is for my inferno case project not yet writen up
  4. Dr.Headshot
    Dr.Headshot What's a Dremel?
    17 Aug 2004
  5. piloux
    piloux What's a Dremel?
    12 Nov 2003
    to crash... :
    you could use the search to find how to rust a case... I think this has been talked about a few time.
    btw : excellent mod Butterkneter :)
  6. *Butterkneter*
    18 Aug 2004
    THX to Piloux
    What a Honor to get acknowledgment by the "Hypermodder"
    here is some more . . .
    here the Sidedoors with the Bulletholes, which TheSchumi copied in his
    mod.
    the CD Storage
    closed . . . .
    open . . .
    here some pictures in the dark
    look at the Bulletholes. . .
    with Case open . . .
    a bit closer . . .
    The "Lambda-Core"
    a self-made Warning sign . . .
    a little accessoir. . .
    Butterkneter
    . . . and here is the Control-Unit
  7. crash32953295@msn.
    2 Aug 2004
    ok jus a little not i jus did a search turned up nothin apart from your exellent half life project, have u made a guide on this?
    and since ur the one in the know, any ideas on a burnt/ sincged effect.
    and again exellent mod *Butterkneter*
  8. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    looks great, although it's this theme is a bit overdone... btw... what is black messa? i still haven't cought what it is :rolleyes:
    this is definately in the top 10 of hl2 mods. I just hope the game doesn't turn out to be a flop :hehe:
  9. Shrapnill
    Shrapnill What's a Dremel?
    5 May 2002
    Um..... TheSchumi posted images of his bulletholes on Aug. 13. How did he "copy" yours that were posted today (Aug. 18)?
  10. fhqwgads
    fhqwgads What's a Dremel?
    24 Jul 2004
    I don't think HL2 mods are overdone, I think the rusting paint effect is overdone. But good mod, eitherway.
  11. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    Its not a question of Quantity
    But it is a question of Quality....
    I don’t care how many H2 or rust mods are done, as long as they are kicka** mods. This is defiantly one. :dremel: Great job.
    <suggestion> You may want to go into more detail on how you made some of your components, like your 'lambda core' or the detail on the door. How did you make those?
    Note to everyone: Get used to seeing these types of mods. A destroyed, aged or rusted mod is a lot more user friendly then trying to build a mod that looks stock, as well as a lot cheaper to do unless you work at a cnc shop. Lets not rag and say "its been done" at least its getting done.... <IMHO>
  12. steff79
    steff79 What's a Dremel?
    10 Dec 2003
    Butterkneter postet "his" Bulletholes in an german forum earlier than aug. 13th. Originally it's his how2 but i can't understand his reaction... that's studip.
  13. preatorian
    preatorian What's a Dremel?
    18 Aug 2004
    who cares about copying bulletholes, the mod rox! ^^
    btw would it be cooler to like 'mask' the purple color and keep it orange with a bit of that radioactive stuff
  14. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    realy nice job :rock: The front realy rules. IMHO, the rust-projects are not overdone. its just a new way of modding, i like them more instead of all those standard modded lian li's and chieftecs without own ideas.
  15. Patmol
    Patmol Guest
    you took with some idea of mod HL2 of Piloux but it is a beautiful mod nevertheless :thumb: :thumb:
    I love the "Lambda-Core" :)
  16. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    This is sicker than Piloux!
  17. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Looks good, just a little too much of the theme now...
    I really like the side panels though and are interested in how the lettering is "painted" on...
  18. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    wow, it really does look like a server version of the blackmesa mod by piloux.. good work though.. despite alot of the cases im seeing following the rust effect.. they are all turnin out to be original in their own way..
    great mod :thumb:
  19. Acid Burn
    14 Mar 2004
    no way... piloux is the one and only when it comes to hl2 mods. and I mean both of them.. this is really great but, nomatter how hard you try you can't beat piloux :) and the fact that piloux lives in belgium which is a crap country when it comes to finding good parts, makes his mods even better.
    can anyone tell me what black messa is?
  20. *Butterkneter*
    18 Aug 2004
    You should play Halflife . . .
    Black Mesa is the corporation , Gordon Freeman , the main character of the game, worked for.
    Nobody wants to "BEAT" Piloux. This is not a match. Modding is simply fun !!!
