Windows explorer.exe crashing
Discussion in 'Tech Support' started by fleck, 15 Nov 2011.
  1. fleck
    fleck What's a Dremel?
    7 Nov 2011
    im using windows 7 ultimate fully up to date, getting windows not genuine message but that isnt bothering me...
    when trying to access 1 or 2 certain directories my explorer.exe crashes
    these directories have got media files inside, including .mkv files etc.....
    and i get this information in the crash message:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: explorer.exe
    Application Version: 6.1.7601.17567
    Application Timestamp: 4d6727a7
    Fault Module Name: DivXMFSource.dll
    Fault Module Version: 1.0.0.72
    Fault Module Timestamp: 4cffcf66
    Exception Code: c0000005
    Exception Offset: 0003060e
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 2057
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    i cant find anything usefull on google about it
    hope sombody could help before i end up wiping and reinstalling everything lol
  2. short1uk
    short1uk Minimodder
    20 Sep 2011
    Is it all windows updated? Only time I have seen this is again on Win 7 Ult - fake copy and windows update wouldnt run so it was the vanilla copy.
    Kept doing the same - told customer to either buy it or downgrade back to Xp which the machine came with.
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Looks like the divx media handler is causing it to me. Uninstall the divx codec pack.
  4. fleck
    7 Nov 2011
    from what i remeber divx has recently downloaded a new update so yea maybe it is that, ill try this 1st then if not i guess ill be re installing windows 7 and de-activating windows updates, thanks guys
  5. fleck
    7 Nov 2011
    just searched this file "DivXMFSource.dll"
    in this directory: C:\Program Files\DivX\DivX Plus Media Foundation Components
    deleted this file now....explorer.exe doesnt crash anymore while searching my system... thanks alot lysol ur advice worked :clap:
