External Hard drive not showing up
Discussion in 'Tech Support' started by DoNuT, 16 Jun 2006.
  1. DoNuT
    DoNuT What's a Dremel?
    20 Dec 2004
    I just bought a Coolmax HD enclosure and a 160 GB SATA HD for it.
    Links:
    enclosure: http://www.newegg.com/Product/Product.asp?Item=N82E16817146067
    hard drive: http://www.newegg.com/Product/Product.asp?Item=N82E16822148105
    My PC's mobo specs:
    http://www.silentpcreview.com/article222-page1.html
    I did everything the instructions said to do, and it appeared that the drivers were updated when I plugged the HD into the computer with USB and Firewire. The problem is that the HD doesn't show up in My Computer. The computer recognizes that the device is connected by showing the Safely Remove Hardware icon in the lower right-hand taskbar. Is there something really simple to fix this, like setting a drive letter to it?
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Control panel -> admin tools -> computer management -> disk management. Should be an option to "import" (or simialr wording) the disk in there :)
    Might need to format/create a partition on it too
  3. kenco_uk
    28 Nov 2003
    As Highlan3r said, right-click My Computer, click on Manage, click on Disk Management. It may even come up with a wizard asking what you want to do with the new disk. You want to initialise it but don't convert it. Then create a Primary partition on it.
  4. DoNuT
    20 Dec 2004
    Thank you guys a lot. I had to initialize it and then create a primary partition. Learn something new everyday.
