Graphics External Video Card
Discussion in 'Hardware' started by Dash, 7 Dec 2002.
  1. Dash
    Dash What's a Dremel?
    24 Sep 2002
    Is there such a thing becuase I needed a better vid card for my laptop to play some older games like Unreal Tournament but my 8mb vid isn't cutting it and I don't want to fool around opening the laptop. I doubt there is something like that but if there is :cooldude:
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Nope. Even if you did open the laptop then it is likely the gfx card is on the motherboard. I used to work at a place that used plug in gfx cards, but I think they would only fit certain motherboards. God I am so glad I don't work there anymore.
  3. Dash
    24 Sep 2002
    ok thanks
    now to waster what money I had to build a cheap system :waah:
  4. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    You can search for a laptop to buy with something like the GeForce mobility card or something, but you can't get external cards or buy one to replace your existing one. If you open the laptop you will:
    • Invalidate your warrenty
    • See that the inside is very cramped and difficult to work in
  5. j`w0n
    j`w0n What's a Dremel?
    17 Jul 2002
    Get an Alienware laptop.
  6. Dash
    24 Sep 2002
    I would if I could :D but I am broke and my current laptop is all I got for the road. Maybe next years student loans I will buy a shuttle or something
  7. Altron
    Altron Minimodder
    12 Dec 2002
    Alienware laptops are SOOOOO expensive.
    LOL coming from the guy who's saving up to buy $1600 computer.
  8. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    there are USB -> ISA adapters out there...soo it isnt completely out of the question...but its like an ISA card will do u any good...
  9. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Are there any USB 1.1/2.0 -> PCI cards out there ?
    That would be real nice :D
  10. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
  11. sinizterguy
    25 Jul 2002
    I had been to that site ... didnt find a pci adapter ... thats why I asked :) ..
