PSU Extra long cables
Discussion in 'Hardware' started by kelvinb, 7 Dec 2011.
  1. kelvinb
    kelvinb BF3 Username - D0rmarth
    20 Sep 2011
    Hi all,
    I am currently looking for an upgrade for my PSU, ideally I would like the PSU with extra long cables as the current PSU does reach the point correctly and I have to use extention cables to reach the connection points.
    The ideal PSU needs enough power to run 2X GTX 460 in SLI and reach all the connection points. The case I am using is the Corsair 700D so you can see my problem
    Any ideas on whats the best PSU for this
    Many thanks :D
  2. MrTeal
    MrTeal Minimodder
    27 Aug 2010
    What PSU do you have atm?
    NZXT Hale90 series have 70cm long ATX12V/EPS12V cables, unfortunately they are not available in the UK anymore - certainly not at reasonable price.
    The Silverstone Strider Plus and Gold series have 75cm long ATX12V/EPS12V cables. The PCIe and 20+4 pin ATX cables are 55cm long, don't know if this is long enough for the Obsidian 700D. Availability and pricing of the Plus 750W unit is good.
    kelvinb likes this.
  3. faugusztin
    11 Aug 2008
    I don't think you would have problems with any better PSU, probably the only exception is the EPS 4/8-pin, which can be problematic in length area.
    Corsair AX750 has :
    Cables and Connectors
    Seasonic X-750 has :
    Considering the height of the whole case is 60cm if i remember correctly. you have more than enough length with the 55-60cm of both power supplies i mentoined for 24-pin and PCI-E, but you will have problems with 4/8-pin EPS cable - that will require an extension with pretty much all power supplies.
    kelvinb likes this.
  4. kelvinb
    20 Sep 2011
    Many thanks both for your input, due to the customer services of Corsair I think ill go for that one. Cheers and +rep to you both
