Motherboards Extremely slow shutdown on new system with SSD
Discussion in 'Tech Support' started by talladega, 4 Jun 2012.
  1. talladega
    talladega I'm Squidward
    18 Aug 2007
    I just put together a new H77 Mini Itx system with a solid state drive in it. Starts up insanely fast. About 15 seconds power pressing power button to being in windows and ready to open any program.
    However it takes FOREVER to shutdown. I'll go to the start menu and click on shut down and it takes just a couple seconds to get to where its saying shutting down. That only is there for a few more seconds until the screen goes black as though the system is going to power off, but then it sits like that for quite a while before finally shutting off.
    I also noticed that when in the BIOS and I press Save changes and Exit, it takes quite a while for it to reboot as well.
    Is it a bad motherboard?
  2. Deders
    Deders Modder
    14 Nov 2010
    My first instincts want me to ask you:
    1: What is your motherboard
    2: What kind of sound chip are you using?
    3: Is everything up to date, and do you have dot net framework 4.xx installed?
    4: what operating system are you using?
  3. talladega
    18 Aug 2007
    Motherboard:
    http://www.asrock.com/mb/overview.asp?Model=H77M-ITX
    Onboard sound
    All Updates Done
    Windows 7 x64 Pro
    It does this even in the BIOS. If I press the power button to shut it off or do CTRL-ALT-DEL to reboot it takes a long time as well. I very much doubt it is software related as I have done this with no devices plugged in and all features in the BIOS disabled.
  4. rollo
    rollo Modder
    16 May 2008
    sounds like a bios setting to keep the fans spinning for 30secs to 1min
    i know i have a similar bios setting that allows me to cool the system down before it fully shutsdown
  5. talladega
    18 Aug 2007
    I tested it with another PSU that I know works perfectly and it did the same thing. Also looking for settings like you mentioned and found none.
