Windows Fallout 3 GOTY Fix?
Discussion in 'Gaming' started by Greg_Head, 17 May 2013.
  1. Greg_Head
    Greg_Head What's a Dremel?
    21 Apr 2013
    I'm having trouble running fallout currently, my specs far outdo the requirements (660 ti) and was wondering if anyone had anything as a fix, i've had a look through a couple of forums but nothings worked so far. I'm running windows 7 if it helps. Any help is good :)
    fuus likes this.
  2. Pete J
    Pete J Employed scum
    28 Sep 2009
    What problems are you having exactly? Low FPS?
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Are there any real symptoms of the crash? Does it freeze, fail to start, what? Basic things to do are: Disable AA in game. Use an external AA injector like SweetFX or similar, just because Fallout 3's AA system actually induces instability, beyond that; there's a lot of tweaks you can perform within the INI files to help the game out, the most important is the "iNumHWThreads=2" tweak, to prevent the save system crashing the game.
    I sourced all of my information from here http://www.tweakguides.com/Fallout3_1.html and most of what worked for me was just found by tweaking and fiddling till the game behaved, it's an annoying process, but the game does still look very good with a couple of high-res texture packs and Fellout installed.
  4. Greg_Head
    21 Apr 2013
    Main problem is I play the first bit do the SPECIAL book and then just crash.
  5. loftie
    loftie Multimodder
    14 Feb 2009
    I used to have this, then it mysteriously stopped. The only thing i can recall trying was numerous reinstalls. And the latest install I modded it. Still got bored :(
  6. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
