Case Mod - Complete FALLOUT 76 casemod
Discussion in 'Project Logs' started by pccustom, 9 Jul 2019.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    sharkoon commissioned me this case for milan gamesweek 2019 which will be exhibited in their stand, it is not the first time I realize a fallout76 casemod enjoy
  2. pccustom
    12 Jul 2017
  3. pccustom
    12 Jul 2017
    Theophilus_Field and arduum like this.
  4. pccustom
    12 Jul 2017
  5. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Nice build mate the rust looks real.
    pccustom likes this.
  6. FatmanSoldier
    FatmanSoldier What's a friggin PC
    12 Jan 2010
    Looks amazing. Well done mate.
  7. pccustom
    12 Jul 2017
    Dot_Kappa likes this.
  8. Cheapskate
    13 May 2007
    Lovely. :D
  9. Brett89
    Brett89 Minimodder
    15 Dec 2005
    This is some awesome paint! Looks awesome!
  10. pccustom
    12 Jul 2017
  11. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Awesome!!!:thumb:
  12. Theophilus_Field
    Theophilus_Field If all else fails... use the surfacing tools
    17 Oct 2013
    Superb paint skills, it really gives the case character!
  13. pccustom
    12 Jul 2017
  14. pccustom
    12 Jul 2017
    tempered glass side panel engrave.
  15. Cheapskate
    13 May 2007
    How exactly did you make that template? It looks like you had to break something to get the pattern.
    Did you punch the masking with it on a cushion and then cut off the wrinkled parts?
  16. pccustom
    12 Jul 2017
    I worked on this photo http://www.transparentpng.com/details/broken-glass-effect-transparent-_422.html
    with photoshop with the color levels, I get only a white and black, then I worked with the silhouette program and I got a track to make cut on vinyl and then put the paste, it's very simple, I assure you that the glass is not broken but it is only superficially engraved to have this effect.
    Cheapskate likes this.
  17. Vault-Tec
    30 Aug 2015
    Never seen such an appalling game get such an incredible mod.
    Your work skills are amazing.
  18. pccustom
    12 Jul 2017
  19. pccustom
    12 Jul 2017
  20. pccustom
    12 Jul 2017
