Cooling Fan controllers, pump relay
Discussion in 'Hardware' started by abezors, 21 Sep 2010.
  1. abezors
    abezors Lurking since '08
    21 Apr 2010
    I have a Scythe Kaze Master fan controller, which has a maximum load of 1 amp per channel.
    I would like to have some basic control over my water cooling pump (EK DCP 4.0), and thought I could rig it up to this. However, this pump draws 1.8 - 2 amps (depending on load/ startup draw etc). This also means I can't plug it into motherboard headers (Gigabyte have 1a max).
    Since I don't want to overload the Scythe controller, I was thinking of using a relay - the fan controller's potentiometers would hopefully control (but not power) a separate power source for the pump.
    Alternatively I could buy a different fan controller, but there aren't many that have suitable power delivery AND match my case (brushed black aluminium. My Scythe has a custom fascia).
    If all else fails I will resort to using a 5v resistor cable (pump starting voltage is rated at 8v, though mine runs fine at 5v).
    So, does anybody have any experience, thoughts or pointers? (PS I noticed there are plenty of pump + relay guides on the net, but nothing like this. They are all aimed at 240v mains AC pumps that are plugged into the wall).
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    For what it's worth, i ran my XSPC X2O pump-res combo off of a Zalman MFC1. It ended up leaking but i'm sure that's not a result of controlling it. I think MaverickWill ended up finding the leak and fixing it, too.
  3. capnPedro
    11 Apr 2007
    It doesn't work that way.
    Also, be careful with the resistor cable. If the current draw is very high, it will burn out the resistor. You'd be better off swapping which pins on the molex cable it's connected to, so the pump is either 5v or 7v powered.
  4. Big Elf
    23 Apr 2009
    The Lamptron FC2 will easily control that pump (make sure there's enough voltage to start the pump though), looks pretty good and isn't a bad price http://www.chilledpc.co.uk/shop/product_info.php?products_id=1832
    My pump's also run OK at 5V and they're a lot quieter at that voltage. A resistor worked fine with mine until I got the Lamtptrons.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    The mCubed T-Balancer series is designed specifically for this, BT did an article on them. Link. The do a selection, so you can pick the one which meets your needs.
  6. abezors
    21 Apr 2010
    Thanks for your thoughts guys.
    Yeah I'd love an mCubed but just have zero time now to configure it properly before I go away, but I've had my eye on the miniNG.
    I have temporarily swapped the molex pin to run at 5v, but prefer to be able to ramp up power if needs be. I will probably stick with this though unless I find something else. I was thinking about the resistor cable being overloaded but wasn't sure, guess you are right.
    If I can sell my Kaze Master I will pick up a Lamptron, they look pretty good! Thanks for the suggestions.
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Which color is it and how much are you looking for?
  8. abezors
    21 Apr 2010
    It's black, but I would only sell it with original fascia (I'm keeping my custom aluminium one!).
    Price I'm not sure of, it has a few light scratches on the front so perhaps £15, not sure yet.
    http://scythe-usa.com/product/acc/028/km01_detail.html
  9. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    How do you scratch up a fan controller? :/
    Anyways, if you can post some pictures of the damage i'll consider it.
