Cooling Fan or Watercooler?
Discussion in 'Hardware' started by jon1984, 23 Feb 2010.
  1. jon1984
    jon1984 What's a Dremel?
    30 Dec 2009
    Ok, ive seen the Corsair H50 watercooler and looks interesting, just wondering if watercooling is any better than a Titan Fenrir or Gelid Tranquillo?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Depends on what you're bolting on to.
    It's comparable to a Fenrir providing you get the airflow direction right.
  3. Jipa
    5 Feb 2004
    What CPU and case are you using?
    Performance-wise you most likely aren't going to see a difference that would matter.
  4. shah
    shah Minimodder
    29 Jan 2010
    I have one and is running on i5 750. the temps are like 10c lower than the stock cooler. I have this setup in Fractal R2 case. i have only two fans in my case, one running at the front and 2nd one at the back with rad attached to it. I hope this give some sort of an idea.
  5. saspro
    saspro IT monkey
    23 Apr 2009
    Have you reversed your airflow?
    It really needs a direct air feed from out of the case to be effective.
  6. shah
    shah Minimodder
    29 Jan 2010
    Oh well I have done that but it does not make a big difference and the GPU gets very hot as it keeps all the hot air inside. so i decided to stick with the normal air flow. I want the system to be quiet as well thats the only reason i got H50.
  7. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    I have the H50 on an i7 920 at stock.
    Sleep mode = 20 degrees, basic operation = 30, Gaming = 40-45.
    Close a game and the temp drops back to 30 in about 5 seconds.
