Graphics Fan rattle
Discussion in 'Hardware' started by Greentrident, 19 Jun 2018.
  1. Greentrident
    Greentrident Minimodder
    10 Jul 2009
    I've got a slight rattle on my R9 380 - are there any aftermarket coolers worth bothering with or should I go for a replacement part? Or does anyone have any suggestions for fixing without replacing the fan?
  2. adidan
    25 Mar 2009
    Have any of the fan screws worked themselves a bit loose?
  3. TheMadDutchDude
    23 Aug 2013
    If it’s definitely the fan, you can grab replacements on eBay. :)
  4. Greentrident
    10 Jul 2009
    I can't see any loose screws- will have to try removing the fan setup and tightening it up before I buy a replacement fan. Are there any all in one water coolers that are worth thinking about or are they a waste of money?
  5. TheMadDutchDude
    23 Aug 2013
    They are all much of a muchness. However, adding a cooler that is pretty much worth what your card is worth seems like a poor financial choice.
  6. Big Elf
    23 Apr 2009
    If you have the space and depending on the heatsink type you can sometimes remove the existing fan and zip tie a 120mm one onto the heatsink as a cheap fix.
  7. Greentrident
    10 Jul 2009
    This is very true!
    I think I can get a replacement set of fans for about £15 on ebay so I'd be better off doing that. I'm hoping to upgrade soon now that prices are coming down so would ideally like it in saleable condition!
  8. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    What version of the R9 380 do you have? For rattle it might just need application of a little fine machine oil which is a very cheap fix. Did the same myself to a 5870 with blower fan design and sorted the problem.
  9. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Machine oil or another light oil should be in everyone's tool kits for computer maintenance. I have double and tripled the life time of fans (per manufactures' MTTF) by simply cleaning and oiling.
