Graphics Faulty fan MSI Twin Frozr fix
Discussion in 'Hardware' started by Nutyy, 25 May 2017.
  1. Nutyy
    Nutyy Widden Palettes
    24 Aug 2010
    Hi guys,
    I have an old MSI 560TI Twin Frozr that i replaced last year due to the one of the fans being faulty, it starts up for a few seconds then stops, The fan itself seems to be reluctant to move, i blow some compressed air in the direction its supposed to turn and it doesnt move, but the other fan spins for a bit before stopping.
    Is there anything I can do to try and fix it?
    Cheers,
  2. Vault-Tec
    30 Aug 2015
    Yes, replace the fans with after market ones and run them from the PSU or mobo.
  3. Nutyy
    24 Aug 2010
    Cool thanks, yeah i took off the heatsink so will need to get replacement fans
