well heres my little story i tried to change my file folder icon, and when i did that it screwed with the actions for the folder. now when i click and file folder it opens it in another window (and yes i have all the options set to open in the same window) and when i right click instead of the Open option (not even there) being bolded. the Explore option is bolded This is all on windows xp pro. someone please help. i think i could change it if i know whate the extension ig uess it is would be in the registry because .folder is there but its not the right one.
did you go into tools>folder options>file types and mess around in there by any chance? I've had this problem. I solved it with a quick registy edit: http://forums.bit-tech.net/showpost.php?p=868247&postcount=5
