Storage Finally! Decent 64GB SSD extremely close to £99.99...
Discussion in 'Hardware' started by Ph4ZeD, 29 Sep 2010.
  1. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
  2. markbrett64
    markbrett64 thanks to denial I am now immortal
    12 Jan 2010
    I seem to recall reading somewhere that Sandforce, once refined, would allow the use of lower quality NAND without performance loss...
    Or did I imagine it? Wouldn't be my first case of wishful thinking....
  3. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Does this mean we'll hopefull see 128GB ones for £200?
  5. Shadow_101
    Shadow_101 Minimodder
    12 Feb 2004
  6. Ph4ZeD
    22 Jul 2009
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    There was a sale on certain SSD at newegg. I think it was a 30gb SSD for $60, so $2 a gigabyte. Which isn't bad considering it's a frickin SSD
  8. Bloody_Pete
    11 Aug 2008
  9. AngusW
    AngusW mmm
    20 Oct 2009
  10. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
  11. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    oooo this means a happy Christmas i reckon!
  12. kenco_uk
    28 Nov 2003
    Hmm.. for those thinking of getting an F60, there appears to be incompatabilities a-go-go with the drive, meaning you may have to switch a load of power-saving features off for the drive to be useable. Maybe a firmware update may fix it, who knows?
    You'd probably be better off getting an OCZ equivalent for about a fiver more. At least it should work properly.
    Booga likes this.
  13. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    Im just trying to tell myself that my MBP doesn't need an SSD.... but it does
  14. Booga
    28 Sep 2009
    Thanks for the heads up.
    I was leaning toward the OCZ myself, who knows in 2 weeks they might also be sub 4 monkeys. :D
  15. Booga
    28 Sep 2009
  16. Ph4ZeD
    22 Jul 2009
    Its £96 on Scans Today Only.
  17. Booga
    28 Sep 2009
    Dam BD is not for another 2 weeks :(
    Mind you should be cheaper by then :clap:, unless they go the way of DDR2 RAM :jawdrop:
  18. shifty27
    shifty27 What's a Dremel?
    30 Sep 2010
    The OCZ sandforce is better as they had first access to the firmware.
    I ordered mine off of ebuyer for under £100. Its a better deal than the Corsair as there is reported issues with power states and no firmware release date as of yet!
  19. jrs77
    jrs77 Modder
    17 Feb 2006
    The problem with all those SSD-models is, that you can't tell what controller is used actually, before you've bought and tested it.
    The OCZ Vertex 2E is available without SandForce controllers, so they might sell those older SSDs for lowered prices now.
  20. Andrew G
    Andrew G Where's my Crayons!
    17 Jul 2010
    If I wanted to buy a c300 (64Gb) on a socket 775 board would I be better off getting also a 6Gbps PCI Express card so that the C300 ran at full speed. I see in this months build list they recommend a c300 64gb on the gamer build without mention of needing an add on card but the more expensive system with the 128gb c300 has the Lycom card? Or does the cheaper 64gb version not have a 6gbps port?
