News Firefox 3.5 now available
Discussion in 'Article Discussion' started by Tim S, 1 Jul 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Good because my old Firefox has been freezing up lately. Sad to have to switch back to IE :(
  3. MajorTom
    MajorTom Minimodder
    14 Aug 2008
    Been enjoying it since yesterday evening. The Weave Sync addon is just brilliant. Goes a little further than xmarks and syncs your tabs for when you get back from work. Very nice work in progress.
  4. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    What is "Tear off tabs"?
  5. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Is it compatible with flash? Normally I have to wait for flash to be available to new variations of FF
  6. RTT
    RTT #parp
    12 Mar 2001
    Drag a tab off the tab bar to open it in a new window. you can drag tabs between windows too
    yes it is
  7. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Ah! Thanks.
    But the "drag tabs to another window" was already available on previous versions.
  8. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    Ummm where is 3.6? I have been on 3.5 for ages now, next please, lol
  9. Psy-UK
    Psy-UK What's a Dremel?
    22 Jan 2009
    This is the final release. You've been using the RC or Beta versions.
  10. capnPedro
    11 Apr 2007
    I'll give it a few weeks before I upgrade. Wanna make sure all my extensions and skins and such work. They're very important to me!
  11. V3ctor
    10 Dec 2008
    Eveything works fine here... No problems at all, even with the extensions...
  12. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Loving the tear out tab. Opera had this before didn't it?
  13. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I'll probably get this for work, as it's a new JS engine, but don't think I'll bother at home.
    IE8 and Chrome occasionally serve my browsing needs. (Dons flameproof suit)
  14. sear
    sear Guest
    Been on 3.1 and then 3.5 in various beta iterations for probably at least six months now. I've been quite happy with it, and have had very few issues with stability or performance (most of those cleared up before the release candidate stage), but I guess the changes may not be as drastic to me, as I've seen then added in one-by-one in each version.
  15. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Rendering is sloppier in 3.5, I find.
    It's prone to flickering/jumping with fixed-position backgrounds in CSS, which didn't happen in previous versions nor in IE8.
    On the upside, it now only supports the standards-compliant opacity option in CSS and ignores the IE and Netscape opacity filters.
  16. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Hm, last time I tried a manual update, I lost all my settings and bookmarks. Going to wait for auto-update to get fixed.
  17. Tim S
    Tim S OG
    8 Nov 2001
    not sure about Opera, but Chrome has it.
  18. wyx087
    wyx087 Multimodder
    15 Aug 2007
    also Safari, if you don't mind Apple.
    3.5 is fantastic, i can now go back to single browser. although it'd be nice to be able to have private mode by window instead of by session. eg, 1 private mode window, the other normal mode.
  19. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Installed it this morning, and am liking it.
    JS rendering is deffinately quicker. All the sites i've made still work (very good thing, that), and as such i am a happy camper.
  20. adamc
    adamc What's a Dremel?
    12 Nov 2007
    Any ideas why the installer is trying to force me to install to C:/ProgramData instead of C:/Program Files (x86) ??
Tags: Add Tags
