Build Advice First build for Uni, components help
Discussion in 'Hardware' started by TheManicGibbon, 9 Aug 2012.
  1. lm_wfc
    lm_wfc Member
    18 Feb 2011
    That's the thinking!
  2. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    Haha thank you! I'm trying to spend as little as possible for the best machine possible...
    I'm now also thinking that I might up it to 16GB of RAM because Scan are selling off some low profile Corsair Vengeance for £30 for an 8GB kit, seems like a steal.
    UPDATE:
    Just gone and placed my order with Scan;
    Intel Core i5-3570K
    8GB Corsair Vengeance
    Gigabyte GA-Z77-D3H
    Corsair CX500W PSU
    Antec Kuhler H2O 620
  3. TheManicGibbon
    12 Aug 2009
    I should be getting all the parts tomorrow but here's a question for the expert builders out there; how essential is an anti-static wrist strap?
    I've worked with PCs a lot, and I'm well in the habit of frequently grounding myself on a case or radiator beforehand. I've never used a strap before when I've upgraded graphics cards, hard drives, memory etc.
    I'd be working on a hard floor (not carpet) and building on a wooden table. Any comments?
  4. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    I've built 20ish now and not used a wrist strap, seems redundant, just ground yourself on something nearby and avoid wearing nylon shell suits on wool carpet :blush:
  5. Deders
    Deders Well-Known Member
    14 Nov 2010
    I believe there are very few chips that actually get affected by static, but better safe than sorry
  6. TheManicGibbon
    12 Aug 2009
    Okay, I am very careful with earthing and stuff and it's the same thing really.
  7. Deders
    14 Nov 2010
    Just be sure to discharge yourself before you open the case
  8. TheManicGibbon
    12 Aug 2009
  9. theshadow2001
    3 May 2012
    I always wear a strap. There's plenty of anecdotal evidence that you don't need one. But of those people who say you don't need to wear one. How many have the ability and inclination to actually diagnose if a fault was caused by electro-static discharge. Apparently faults aren't instantaneous but can degrade connections and the like causing problems later on down the line. Really its not that hard to wear a ground strap and it only costs a few quid.
    Also grounding yourself on a case isn't very good if you are touching a painted case. It needs to be bare metal
  10. TheManicGibbon
    12 Aug 2009
    This is a very good point. Seeing as the CM690 II is painted inside, this could make things difficult. I guess I could just use my old case to earth as I'll have that beside me as I swap components. Cheers for that, I never thought of that.
  11. theshadow2001
    3 May 2012
    Remember you need to earth the case as well, it can't be just a metal case. My case is plastic or painted. When I was rebuilding I installed the power supply. Then I screwed a screw into an unused hole somewhere in the case. I then used that screw as a bonding point. It's unlikely for there to be any paint in the threads of the hole and if there is, turning a screw in it will strip any paint thus making the ground connection. This is how the power supply connects the case to ground, through the screws you use to install it.
  12. TheManicGibbon
    12 Aug 2009
    Thanks, that's a good idea. Makes sense about the power supply too, I'd never really thought about it.
    UPDATE: Bought and built all the parts successfully. Ended up getting another 8GB of RAM because it was cheap on Scan! Adam from Scan was also a top lad, upgrading me to a CX600W free of charge when it transpired that my CX500W was out of stock and therefore holding up my order. Yet again top marks to Scan.
