Scratch Build – In Progress First Scratch Build, Monolith?
Discussion in 'Project Logs' started by pAcMan, 31 Aug 2011.
  1. pAcMan
    pAcMan What's a Dremel?
    22 Jul 2011
    Upplands Väsby | Sweden
    Hello Everyone
    So, this is my First projekt. It has been inspired buy Mystikal0412 Exoskeletonwith themes inspired by the Warhammer 40000 Necron Monoltih
    The Marerials that I will use, will be mostly Plexi.
    These are some pre-production SkecthUp Pictures, of how It will kinda look like.
    This is a picture of the bottom of the case, the big black box is the PSU and the black cover around it is to cover up those nasty cables. The hole is for a 120 mm intake fan.
    And here is an more detailed version of it, how I will mount the fans etc.
    My Current Dilemas are:
    How to mount the motherboard, since I don't think I got a spare computer case.
    How to get a good airflow thru the system. ( I am thinking about cutting out a hole in the bottom of the case, where air will be pulled thru (not the 120 mm hole but a smaler one in the front forgot that one in the SkecthUp Picture) but I do not know if that will be sufficient to cool my system, or if I should raise the black plexi and have holes under them, but I do i think it will ruin the look.)
    So what are your thoughts?
    /pAcMan
  2. Harryo
    Harryo What's a Dremel?
    7 Sep 2011
    Sorry for my bad english but I will try to explain as good as I can.
    About the MB I think that you should build a removable motherboard case(just like the ATC 840) and cut holes for the cables but leave some plexi(or other material) for the screws. About the airflow I think you can use the same setup as in the Raven pc case where the MB is turned 90 deegres so the graphiccard is turned up. With that I would use 1 or 2 intake 120mm fans in the bottom of the case and 2 at the top pulling out the warm air.
  3. pAcMan
    22 Jul 2011
    Okey, I see.
    I am thinking about doing something like the ATC 840, but not as complicated. I not think that I will turn the motherboard since I think I will be hard to have the cables not ruin the look.
    Could it work if I have the motherboard more in the middle of the chassi, so that I do not have to make an I/O plate and expansion slots, but I do not know just yet how I will do.
    I will make an update with the motherboard I will use and some more SketchUp pictures.
  4. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    France
  5. pAcMan
    22 Jul 2011
    Hehe, no, but I like the design :p
    Here are some quick updates on the bottom and the back from the inside view.
    Do you think the hole in the front will be sufficient? I think it is 5 cm (2") Times 16 cm (~6")
    And how should I do about the motherboard tray? Should I have it more the the center to avoid expansion slots and I/O panel? And keep the Monolithic design on the back to?
    And here is the Moderboard I will use, XFX nForce 780i, thought it would fit nice with the green and black.
    /pAcMan
  6. robi09
    robi09 What's a Dremel?
    20 Jun 2011
    Birmingham, UK
    Scratch looks great! I'm to my first scratch build too, you must be patient. ;)
  7. pAcMan
    22 Jul 2011
    Small Update, since I do not have my Saw yet I can't start cutting, but I will still work on the design, I now know how I will mount the side panel, I will slide it in. :)
    And here are som SketchUps and a little teaser on my plexi :)
    The Green Plexi
    The Black Plexi, Shiny?
    Yes, Shiny
    My Rig
    And How the rig will look thru plexi, I know the center line is not so sharp, stupid wind.
    This is how I am thinking about mounting the HDD, you can also see the "grooves" I made to let the side slide in.
    Side Panel from the front.
    And a detailed view of how the should fit together.
    /pAcMan
  8. xMathiasD
    xMathiasD What's a Dremel?
    15 Mar 2009
    Denmark
  9. pAcMan
    22 Jul 2011
  10. pAcMan
    22 Jul 2011
    WOOO! Progress! Finally Started!
    My first cuts today, I need to fix one of the sides, since it is not straight enough, but for a first time use with a "sticksåg" I am very happy :)
    As I said, not the best cuts, but I am happy :)
    How It will look from the inside.
    How it will look from the bottom
    Will try to cut more Tomorrow :)
    pAcMan
  11. Stark.Jr
    Stark.Jr What's a Dremel?
    22 Mar 2011
    In my dreams
    Like your design and i hope you the best whit your first Scratch Build :)
    I will follow :D
    //S.Jr
  12. Skeese
    Skeese What's a Dremel?
    2 Sep 2011
    Good luck! :)
  13. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Manchester, UK
    Good luck with the scratch it looks a nice design, the black and green combo will be a great look
  14. pAcMan
    22 Jul 2011
    A little update, just text though.
    The side, back and middle panels are done with the outline cutting. The bottom is now completly done, screw hoels have been added to attach the fans.
    Will try to get some photos of it progress tomorrow.
    /pAcMan
  15. james888
    james888 What's a Dremel?
    13 Mar 2011
    Idaho, America
    I am planning scratch build and was wondering how to connect a side panel. Your idea works with my build. I may use when I finally get there.
  16. pAcMan
    22 Jul 2011
    Okey, If you don't mind screws that is aloooot easier :p
  17. Mystikal0412
    Mystikal0412 Safety First, Think Twice!
    31 May 2011
    Etten-Leur, Netherlands
    Sorry, I missed your PM (5 months ago...). Great to hear that we actually inspired you to make a casemod as well!
    Not sure what the status is on this mod? If I can give you advice, try to connect the lines from the bottom of the green window to the top. That would give it a more total idea.
    Please give us an update. I will inform SqUeD as well on this mod!
    Keep it up!
  18. james888
    13 Mar 2011
    Idaho, America
    Man. I would like to but I am not able to right now. Time and money issues. I would love to make a scratch mod. It would be my case that I would design to be just an amazing case. I have ideas kinda based of silverstone and corsair. Nothing much.
    To sum it up... I would like to make a scratch build but I am just not able to right now.
    Thanks. I'll keep you in mind.
