Modding fish tank mod :eyebrow:
Discussion in 'Modding' started by jamnog, 26 Aug 2002.
  1. jamnog
    jamnog Guest
  2. Fly
    Fly inter arma silent leges
    31 Aug 2001
    :eyebrow:
    Hmmmmm... Interesting....
  3. n0fear
    n0fear What's a Dremel?
    26 Aug 2002
    yeh i've seen that before, pretty original mod :)
  4. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    mod? the woman in a tho tho thon thong? i dont see any computers..
    :D :D
    That is pretty trick too would be cooler if it was a water cooled rig, and instead of a heater for the fish, the cpu would do the job.. hrrmmm.. :cooldude:
    -scooob8000
  5. Raven
    Raven What's a Dremel?
    3 Jul 2002
    I wonder how he transferes the heat away from the tank. He might one day wind up with cooked fishies...
  6. pudknocker
    pudknocker What's a Dremel?
    26 Aug 2002
    you better hope you dont lose any water mater mite cost you a bit
  7. George
    George Bah
    14 May 2002
    u can just imagine that...
    computer (electricity), water & fish = DEAD FISH.
    computer (electricity), water & fish = DEAD COMP.
    Would be a nasty find!
    However, its really nice. Nice find. :baby:
    .icecube
  8. n0fear
    26 Aug 2002
    Why doesn't the heat from the PC make the water hot enough to kill the fish?
    A) The location of the tank is isolated from all the components that generate heat. Several fans are placed in the case as well to move the air though. When the computer has been on for a long period of time, there is a slight increase in the water temperature, but not enough to exceed to livable range of the fish. One of the reasons that I selected the neon tetra was because of it's small size and it's rather large temperature range (23C-28C).
  9. Lazy
    Lazy Meow?
    13 Nov 2001
    maybe they are tropical fish :)
  10. pudknocker
    26 Aug 2002
    thay are i got some in my tank i feed them to my fish
  11. Raven
    3 Jul 2002
    Kewl, thx I stand corrected. I would have tought that with the amount of water you have, your computer could never get hot enought to heat the water to such a degree. But as in all things it would simply be a matter of time.
    Another good answer would have been Plastic fishies... hehe
    All I know about fish, is that once the sucker is hooked, he'll give ya one hell of a figh. (Salmon and Rainbow trout fishing).
  12. n0fear
    26 Aug 2002
    glad to help..
    its always best to read the whole page before asking :p
  13. Hiren
    Hiren mind control Moderator
    15 May 2002
    Damn cool mod there. Very interesting indeed.
  14. Netsrik
    Netsrik What's a Dremel?
    25 Aug 2002
    Is that link broken for anyone else?
    It is for me :cries: , sounds like its pretty cool though.
    EDIT: Working now.. Veeeery interesting.
  15. Seth
    Seth What's a Dremel?
    14 Mar 2002
    thats cool, I have a fish tank with a blue led shining up at the bubbles from the bubbler, and a green one shining on a rock.
    yes the leds are in the tank :) no my fish are not dead :p
    so that is my fish tank mod heh, thinking about adding a laser or something heh.
  16. jamnog
    jamnog Guest
    nice one seth sounds cool. i used to keep tropical fish the neons the guy was using are pretty hardy fish. as fo the temp of the water i expect he has a thermostat controlled heater. if the heat from the case heats it too much then the thermostat switches of the heat and the puter takes over. i found that 76 f was a good temp to keep most fish at. i was thinking about the use of the tank as a resivior and the rad. if you ran the water thru enough and replaced it and if you where to test it for impuritys. then if you have a second submerged fluval and if it was a 2 foot tank then... it might just work but i dont want to try till im shure its safe this is why i need a cheap water block with a 1/2" if i could link the cpu frequency to the temp of the tank then i could use it to heat the tank too. i wouldnt want to hurt the fish tho so will just do it with out the fish.
  17. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    i hope fish aren't sensitive to em fields :D
    me wants a case with pet mice in now
  18. bmh.01
    bmh.01 What's a Dremel?
    7 Mar 2002
  19. n0fear
    26 Aug 2002
    i have a pond with about 10 fish!
  20. jamnog
    jamnog Guest
    i sugested that in the what would you like to see the bit tech team mod next. i figured they could make the mouse power a fan or sommink.
