Storage Flash Drive Fat32 or NTFS
Discussion in 'Hardware' started by Bugste81, 2 Mar 2012.
  1. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    Just ordered a Patriot Supersonic 32GB USB 3.0 flash drive.
    Should I format it as Fat32 or NTFS?
  2. longweight
    7 May 2011
  3. suragh
    suragh Minimodder
    26 Nov 2011
    Fat32 disk can be moved to practically any pc or os without issue but it only supports 4 gig max (which sucks) because I think its faster. As your using a 32GB usb, go with NTFS
  4. murraynt
    murraynt Modder
    6 Jun 2009
    Fat32. Otherwise you will run into problems with devices that don't run windows.
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    It depends where you're using it. If it's going to be used in a Windows environment exclusively, then NTFS is the best option as it doesn't have a 4GB file size limit like FAT32. If it's going to be used under Linux/Mac OS or anything else, go for FAT32, limited file size but it will work pretty much anywhere unlike NTFS.
  6. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    exFAT. No 4GB file limit and runs on Windows, OSX etc. Wont work on PS3 though.
  7. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    exFAT, like Jaybles said. It works on almost every operating system with no size limit.
  8. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    that is the one i am ordering!! :)
    i have only heard good stuff about it
  9. DaveMon
    DaveMon The end is nigh! Repent!
    21 Jun 2010
    +1 for exfat.
    Sent from Bittech Android app
  10. noizdaemon666
    15 Jun 2010
    exFAT causes performance loss though.
  11. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    I am curious about to what extent that is causes a performance loss. I have been using exFAT for my USB 2.0 drives and havent noticed a change. Would I with USB 3.0?
  12. leslie
    leslie Just me!
    19 May 2009
    Fat32 doesn't have a 4gig limit, however due to clusters, it becomes less efficient above 4gigs. Above 8 it starts to really become bad, but if you are only storing large files you are fine. However that presents another issue, since fat32 can't store very large files.
    NTFS or EXfat is your best options, though not everything will read and write to it, most modern systems can.
  13. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    Based on previous usage, i was under the impression Fat32 cant have SINGLE files over 4GB, max capacity of the drive is up to 2TB. exFat overcomes these issues though, and i believe is supported by Windows, OSX and Linux.
    If you are using windows only then NTFS will be best, if you use a mix of OS's then exFat.
  14. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Windows throws a hissy fit whenever you try and put a file >4GB onto a FAT32 partition.
    Do you mean the actual partition sizes rather than file sizes, as you say fat32 can't store large files, which would be contradictory to "fat32 doesn't have a 4GB limit"?
  15. j4mi3
    28 Jun 2011
    as far as i know, the 4gb limit refers to single files. its slightly confusing. you can have a folder which might be 10gb, but it could just be made of loads of 100mb files.
    again, i think this is right. someone correct me if im wrong.
  16. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    +1 for exFAT, though I believe j4 is correct, there is an issue with the reported size rather than actual size on fat32. this is, of course, it's own little PITA as some programs will honour reported size, some will not.
    I want one of these
    ....almost as fast as my intel X80-M!
    (yes I know the patriot is faster...kinda my point....)
  17. leslie
    leslie Just me!
    19 May 2009
    I was referring to formatted partition size, not file sizes. Windows 7 (and a few others) will not even let you format in fat32 if the partition is over 32gigs, there are ways around it but it becomes extremely wasteful.
