Flexible PCI-e riser
Discussion in 'Hardware' started by Asulc, 23 Jul 2008.
  1. Asulc
    Asulc Minimodder
    18 Jul 2007
    I am looking to build a slimline computer. I need to find a good PCI-e riser that is flexible so that the Graphics card can lay down with the fan facing up (rather than facing down and moving away from the motherboard like most of the non flexible risers seem to do).
    I have found a few, but I am concerned about how well they would perform. These two pictures from Sleepstreamer's MCE2.0 are what I am looking for...
    http://images.bit-tech.net/content_images/2008/07/mce2-by-sleepstreamer/l_riser1.jpg
    http://images.bit-tech.net/content_images/2008/07/mce2-by-sleepstreamer/l_packed2.jpg
    Thank you in advance!
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    I don't think you'll see any performance loss.
  3. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Yea should work just like normal. Where are you getting them from?
  4. Asulc
    Asulc Minimodder
    18 Jul 2007
  5. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Asulc, the Newegg one looks to be PCI, not PCI-E, so I reckon it'll be the logicsupply one you'll need.
  6. Firehed
    15 Feb 2004
    Indeed. I'll vouch for logic supply, good guys. Used to live about a half-hour away from them (they were quite literally next door to the Ben+Jerry's HQ, though they moved into a bigger office about a year ago).
  7. Asulc
    Asulc Minimodder
    18 Jul 2007
    Oops...haha. Thank you for pointing that out
    Thank you for the input. I will probably buy that one, unless...
    Does anyone have any others to recommend?
  8. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Flexible ones are hard to find, so I would go with the logic supply people. As for performance they work fine, they usually have a couple of capacitors to help keep the signal intact. They should be fine, you may get some performance loss (very minor), but nothing that the card can't handle (signal clock skew)
  9. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    PCIe uses differential signaling in lane pairs. This allows for some pretty impressive stuff they can do, and distances the signal can go. It is also a port based archetecture rather than a bus meaning cards don't affect each other nearly as much as they do on standard PCI. (it's all in the spec, the trick is finding a !@#$ copy for free) A flexible riser should be fine.
    PCI used the RF characteristics of the boards and slot meaning it was a lot more sensitive to the layout of the board, risers, and such.
    I've ordered from Logic Supply in the past, and I would deal with them again too.
