Modding Flopppy Power Connector pin extractor
Discussion in 'Modding' started by TwiSteD LoGic, 21 Jan 2004.
  1. TwiSteD LoGic
    TwiSteD LoGic What's a Dremel?
    1 Nov 2001
    Ok, I was wondering if anyone knows how to extract the power cables from the starndard power connector for a floppy drive.
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    This is a quickly-made ASCII profile of the pin:
    Code:
    That little tab sticking out of the front is sticking out of the 4 slots running parallel to the connector. All you need to do is push them down (jeweler's screwdriver set comes in handy here) and pull the wire out.
  3. TwiSteD LoGic
    1 Nov 2001
    Thank you very much sir.
    I was thinking perhaps you should post yoru ASCII on deviantart.com. It actually helped alot. =)
