Modding Foot Pedal Mod for Dremels etc.
Discussion in 'Modding' started by japala, 27 Mar 2007.
  1. japala
    japala New Member
    8 Dec 2001
  2. Cardan
    Cardan New Member
    21 Jun 2005
    we have those at school for the dremels in the art room. pretty cool
  3. pendragon
    pendragon I pickle they
    14 May 2004
    If I had the workspace for mine I might be inclined to get that holder and foot pedal as well.. do they work well?
  4. japala
    japala New Member
    8 Dec 2001
    If you know you are about to start a carving job that will take longer, yes, you would like to have the holder for the tool. Takes a lot of weight off your hands making the control of the carving bit a lot easier. Combine this with the foot pedal and you are in carver's heaven. ;)
  5. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Neat! Makes me wonder if it would be possible and practical to make the tip pressure on the carving bit control the carving speed... Just like the pressure sensitivity on a Wacom tablet.
  6. AJB2K3
    AJB2K3 New Member
    12 Dec 2005
    Theres a note in my Dremmel manual saying not to use them because they could damage the control circuitry.
  7. Skylined
    Skylined Active Member
    3 May 2003
    Very nice mod. :)
  8. airchie
    airchie New Member
    22 Mar 2005
    That looks like it just restricts the power going to the dremel itself.
    So I assume you set the dremel to full and feed more current to it the harder you press?
  9. eegg
    eegg New Member
    29 Aug 2006
    prob depends what your doing
  10. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Good point there are those dremel's that are digital in nature, though I much prefer my slide select speed on my dremel. I could see how a digital dremel would not operate properly if you change the input voltage, but I cannot see how it could damage the circuit.
    Then again they have these sorts of silly warnings on a lot of products simply because some idiot found a way to screw it up.
