Budget: £2000 or $3200 Main uses of intended build: Gaming and recording gameplay for video making Parts required: i7 cpu 12-24 RAM 1600 ddr3 good rating sli & win7 compatible motherboard SLI gtx500 series graphic card dual 3d monitor, 22, 23 inch 3x1 TB hard drives Appropriate power supply heat sink, prefer quiet and effecient, no water cooling. a cool looking(optional) case with good air flow. a network card if you think it helps Previous build information (list details of parts): intel core 2 quad e9650 3.0 4g RAM asus p5k/epu gtx280 they are not carried to the new build. but i do have other parts which can be taken off from the budgets: mouse & keyboard can be excluded since i have G11 + sidewinder x8. Nvidia 3d ready i already bought. i have a set of stereo speakers + blaster XFI titanium, so they can be taken out as well. Monitor resolution: wide screen, 22, 23, or 24 inch 3d monitor x2 Storage requirements: 3tb at least, 1tb each for price-wise will you be overclocking: no Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): SLI, good rating Extra information about desired system: order of priority: power > HDD > monitor. if there is extra from budget it has to be able to record and play new games at a good frame rate, minimum 40, ideal 60 i am sry about the re-post because the last post isnt in the correct order, so here is the formal one. thx again, request delete on the last post
