Development Forum login code
Discussion in 'Software' started by cfuk, 12 Apr 2005.
  1. cfuk
    cfuk What's a Dremel?
    9 Jul 2004
    I want to put a login block for my forum on the main page. I have put all the fields and buttons on the page, but i don't know what code i need to use. Can you please help
    p.s. i'm using phpbb
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    surely you could just look at the login template and pilfer the code from there?
  3. Ben
    Ben What's a Dremel?
    11 Aug 2003
    Code:
    <form action="/forum/login.php" method="post" name="loginForm" >
    Username ::
    <br />
    <input type="text" class="post" name="username" size="12" maxlength="12" value="" />
    <br />
    Password ::
    <br />
    <input type="password" class="post" name="password" size="12" maxlength="12" /><input type="hidden" name="redirect" value="" />
    <br />
    <input type="submit" name="login" class="mainoption" value="Log in" />
    </form>
    action="/forum/login.php" == the wherever the login file is for you
    *should work*
