I'm installing everything into a new case, everything wired up ready to go, minus the front panel. Basicly I'm having trouble finding the manual for this mobo, bear in mind it's a fairly old one, even if I can find half a diagram showing the power/led placement that is enough. Any help, links or otherwise would be much appreciated. EDIT: I should add, the header appears to be colour coded, when using this as guidance, wether it be using the power on button or the end of a screwdriver to make the connection I get a very quick 'crackle' very quiet, then nothing kicks into life. Bear in mind also the PSU has been out of the box for only 5 minutes. Power is on fine now, USB header seems to prevent it from booting altogether! in USB1 and 2. Without the front panel USB connected it boots perfectly but only 1 USB port on the I/O panel works. Christ...-_-
I think there isn't a Foxconn mainboard called N15235 although this is printed on the board. The right name is P4M800P7MB-RS2H you should find the right model number printed on the board beside the RAM slot near the CPU and on small label above.
