Hardware Fractal Design Define Nano S Review
Discussion in 'Article Discussion' started by Combatus, 4 Mar 2016.
  1. Combatus
    16 Feb 2009
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Hmm, bit of a mixed bag this one. Has the usual nice Fractal touches, but for me it's still too big - there's tons of empty space, especially in the top front section. Sure, that means room for fat rads and so on, but for a lot of people it's going to be wasted space. 28.8 litres is pretty big for an ITX-only case (contrast with something like the Raijintek Styx which is 25.3l and mATX).
    Can't help but think that this is a bit of a "safe" design really - there's nothing particularly novel or exciting about it. It's basically a shrunken down version of a standard Fractal ATX case, which is fine but not what I'm looking for in an mITX chassis.
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    True. I think one potential excuse for the size is the focus on low noise so you could go a bit overkill on the radiators and have super low spinning fans. Not saying you couldn't have a quiet/silent build in a smaller chassis! And thankfully Fractal is at least going smaller with things like the Core 500 and Node 202
  4. Vault-Tec
    30 Aug 2015
    It so desperately needs a PSU shroud.
  5. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    What's the general opinion of a comparison with a Corsair 250D?
  6. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Sounds like Fractal Designs in a nutshell tbh.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Same as with The Witness' review, there is an 80% score rating on the last page of the mobile review.
  8. Dogbert666
    17 Jan 2010
    Thanks for this, and sorry we didn't catch it before - a relic from the previous system. Should no longer be an issue!
  9. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    No dust cover to swop in for the removable solid roof panel? What a miss!
  10. Splooshiba
    Splooshiba Minimodder
    20 Jan 2012
    Is anyone here planning on buying one / already got one?
    Scan had a pre-order date of March 12th, then it changed to today (March 15th), then changed again to March 31st :sigh:. Does anyone know anywhere else selling this case, or if anywhere else is not getting stocked?
  11. Dogbert666
    17 Jan 2010
    Asked Fractal for you - they said right now it's looking like arriving at dock on March 25th, so the Scan ETA is likely quite accurate!
    Splooshiba likes this.
  12. Splooshiba
    20 Jan 2012
    Good to know, thanks!
  13. Guest-16
    Guest-16 Guest
    Shoulda called it the Nano-L. Looks mahoosive.
    This is going to be the new must have thing isn't it. I agree too!
  14. Splooshiba
    20 Jan 2012
    Yeah its fairly large, but its one of the few ITX cases that can fit AIO liquid coolers and isn't really wide due to a horizontal motherboard. I've got a node 304 at the moment and it just looks like it takes up too much desk... I think my ideal case dimensions would be the node 304 on its side :D.
  15. Splooshiba
    20 Jan 2012
    Scan have some in stock now, more coming on the 31st :lol:
Tags: Add Tags
