News Fractal Design introduces Era ITX chassis
Discussion in 'Article Discussion' started by bit-tech, 19 Mar 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    All the reviews of this agree on two things, it's overpriced and it runs too hot. I wonder how a company as consistent as Fractal could get this so wrong, but collabarating with Intel explains everything.
  3. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Just by looking at it you can tell it will run too hot. no where near enough ventilation and a closed top so you don't exploit the stack effect.
    Arboreal likes this.
  4. Arboreal
    21 Jan 2011
    A missed opportunity, a lot of work has gone into creating a high end alu shell, which looks great with all 3 sorts of top plates.
    Then to starve it of GPU ventilation makes no sense. Lovely for a stylish office PC or HTPC. Anything else is going to cook.
    The mesh top will help, but there's precious little open for incoming air, and a single 80mm fan at the rear.
    I was quite excited when I first saw info earlier this week, but it'll need modding if you want to put high performance kit in it.
    At 16L it is pretty small for a mass market case from mainstream manufacturer, but that space has not been well used.
    As I have said elsewhere, it makes the 12.6L NCase M1 with its 3 slot capacity and excellent cooling all the more impressive.
    Vault-Tec likes this.
  5. fix-the-spade
    4 Jul 2011
    I find the layout doubly strange when Silverstone basically solved bottom to top airflow a decade ago. Some tall case feet, a couple of big fans in the bottom and spin the motherboard through 90 degrees, job done.
    I wonder if's something weird like Silverstone holding a patent on sideways motherboard mountings that stops anyone else from doing it.
  6. MLyons
    3 Mar 2017
    You don't even need to spin the mobo. I did the same layout without spinning it in my mod and it works perfectly.
  7. Paradigm Shifter
    10 May 2006
    Not what I've come to expect from Fractal Design.
    That said, it can't possibly run hotter than a Raijintek Metis (non-Plus), which is a 13.4L case.
    I'd be interested, but I can almost guarantee that it'll be far too expensive here.
    edit: Looking at their site, seems you can swap the wood top for a mesh/filter setup. Perhaps that will help with temperatures?
  8. RedFlames
    23 Apr 2009
    It helps with CPU temps [though not by much iirc], does sweet **** all for the gpu temps.
    Paradigm Shifter likes this.
  9. Arboreal
    21 Jan 2011
    There are quite a few reviews out there; a fair selection on youtube. Just watched Jayz2cents, which was somewhat inconclusive.
    I like Josh from NFC, who is thoughtful and knowledgeable and not out for sensation.
    He seems to think it works better with the top fans as inlets. I will revise my opinion upwards based on his findings. Still not for super high power fire breathing components tho'
    I look forward to seeing what he comes up with for a higher airflow mod.
  10. Vault-Tec
    30 Aug 2015
    It's a total hot box. Watch the HardwareCanucks one mate.
    It would need some modding, but at this price that kinda defies the purpose. There are better cases around (like your one) for not much more or the same.
    They really needed to get this right, and they just haven't.
    Arboreal and Paradigm Shifter like this.
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    According to CraftComputing's review there might also be clearance issues with ATX PSUs and long(er) graphic cards. Namely, you won't be able to connect power cables to the PSU.
  12. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    My view is just go buy a box if you want something unimaginative that does the job, which is literally every other Fractal case. You all just want what already exists out there, regardless of thermal performance, I'm just glad it exists for the sake of not being yet another boring box with less personality than egg and cress sandwich.
    Vault-Tec and bawjaws like this.
  13. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    Is Craft Computing and HardwareCanucks actually doing reviews again, last time I watched either every video was a thinly veiled sponsored advertisement. Jaz2cents is of course going to be inconclusive, he practically works for Fractal. But lets be realistic people, look at a nearly solid panel case and do something stupid like plop a gaming pc in it, how's it going to do?
    Probably not so well, you don't need 1000 reviews to make an educated guess
  14. perplekks45
    9 May 2004
    It looks very interesting, the thermal performance looks meh.
    Watch his video on the Fractal, it seems to be genuine.
  15. Paradigm Shifter
    10 May 2006
    Thanks for the comments folks.
    I usually try to find text reviews, rather than videos - I can read faster than most of those videos talk, skip around with a lot less hassle and avoid the potential fun of an accent or voice which drives me to distraction.
    If I can find one at a reasonable price in Japan, I might buy it just for giggles. I'd like to upgrade my current desktop, but... eh, I dunno. It'll get expensive quickly because beastly ITX rigs always do. ;)
Tags: Add Tags
