Fractal Meshify 2S radiator options
Discussion in 'Watercooling' started by Mordante, 12 Dec 2020.
  1. Mordante
    Mordante What's a Dremel?
    12 Dec 2020
    Dear all,
    When I look at the Fractal Meshify 2S manual I see many radiator possibilities. But I cant find anything about max radiator thickness. Can anyone here tell me what the options are?
    Also it in the manual I read that it's possible to fit a 280 in the bottom. Will that limit the PSU options? I was thinking of fitting in three 280 rads. front, top and bottom. Is this possible?
    On a side note what version of the 2S should I get clear panel, dark panel or closed panel?
    For mobo I was lookting at the: ASUS ROG Crosshair VIII Impact. For no other reason that I like the looks and I think I'll probably have 2 PCIe 4.0 M2 drives.
    KR.
    Drax Mordante
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Looks like you're not limited in thickness, just motherboard height (max 35 mm motherboard component height) for the top. The front is only limited by the top or bottom rad. You will be limited on PSU by the bottom RAD, probably best to assume its as small a PSU as possible, but a back of the envilope calc looking at the dims 200mm will probably be your max PSU length with cables.
  3. Mordante
    12 Dec 2020
    I think I'll order the S2 with the mobo sometime in the next two weeks and start measuring what the possibilities are. A Dutch website (I'm Dutch) has the Alphacool NexXxoS XT45 Full Copper 280mm radiator - silver nickel on sale now almost 40% off. But I'd prefer a HWL GTR 280 but that is a cm thicker.
    Bloody_Pete likes this.
  4. Big Elf
    23 Apr 2009
    Alphacool NexXxoS XT45s are very effective (I have an XT45 480 and an ST30 480), average build quality especially compared to Hardware Labs but performance wise compare very well to the best.
