Displays freesync display with nvidia card ?
Discussion in 'Tech Support' started by stephen0205, 25 Jun 2020.
  1. stephen0205
    stephen0205 Minimodder
    11 Mar 2016
    Soo i needed a second monitor. picked up an acer sa240y. its decent, ips, freesync, cheap and cheerful
    However i cant actually get it to do 75 hz out the box. Or freesync. I only get the option of 60hz.
    I have done a little googling. From what i can see its Hdmi 2.0 (which is the only input other than vga)
    tried it direct with hdmi , tried it with dp adapter to hdmi . Tried a manual overclock in the nvidia settings, black screened. Oddly enough my second monitor which is an ultra wide overclocked above its rated 60 to 75 which was a surprise and nice lol .
    According to the monitor settings freesync is enabled. There seem to be no gync options showing, and im not sure what else to try honestly.
    gpu = https://www.evga.com/products/specs/gpu.aspx?pn=81e0fb30-3f35-469c-b0c5-548cf1de28d7
    monitor = https://www.acer.com/ac/en/GB/content/model/UM.QS0EE.A01
    Any ideas fellas. The extra 15hz isnt much, but id like both monitors running the same, and be nice to know adaptive framerate works
  2. Yaka
    Yaka Modder
    26 Jun 2005
    far as i am aware to invoke gsynch compatible mode its needs a dsiplayport connector hdmi adative synch is only support on amd cards
    adidan likes this.
  3. stephen0205
    11 Mar 2016
    thanks buddy
  4. wyx087
    15 Aug 2007
    This talks about an option in nvidia control panel, worth a look?
    https://www.techspot.com/article/1779-freesync-and-nvidia-geforce/
    Yaka is right:
  5. stephen0205
    11 Mar 2016
    time to plead for a 5700xt lol
