Freezing and restarting
Discussion in 'Tech Support' started by crazyg1zm0, 1 Aug 2007.
  1. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    hello all
    I have just built a new PC made of
    e6750
    p5n32-e plus
    2gb ocz pc6400 4-4-4-15
    7800gt
    500gb s-ata
    250gb IDE
    dvd-rw
    lian-li case
    My problem is that occasionly my PC will completely freeze up or just restart now i have no idea what to do about it so if any of you have any ideas please share and tell me a soloution.
    Peter
  2. mk-donald
    mk-donald bits and bobs
    2 Aug 2007
    Some ideas...
    You don't mention the OpSys. If Windows maybe worth trying to run it in Safe Mode to see if it remains stable in that mode at least.
    Have you installed all necessary 'proprietary' drivers ? eg missing out the latest Via 4in1drivers used to be surefire route to instability on some motherboards.
    If you've overclocked does the motherboard have a fallback/safe/unoverclocked mode to try it at to narrow down ?
    Are you sure the PSU is up to the task ?
    Have you been monitoring the temperatures to look out for an overheat ?
    Finally are you sure about all the components ? After 7 months of stability with a self-built system, I upgraded from a 6600GT AGP to a 7950GT PCI-E a couple of weeks ago, and had one week of stable use, and then the video card decided it wanted to artefact/freeze/reboot the PC. XFX suggested faulty card and RMA. Seems to have been running a bit hotter than expected too. Reverting to 6600GT AGP and all's well again. Awaiting second 7950GT.
  3. crazyg1zm0
    20 Feb 2007
    Sorry I am Using windows Vista and i will check the hardware as the Graphics Card is the only not new bit of kit. and the PSU is a hiper 580w modular and i belive is up to teh task and the tems are usually between 35-40 degrees. and i havent overclocked the system at all yet. is there anyway to test to see if it is the graphics card?
  4. mk-donald
    2 Aug 2007
    What I did with my XFX 7950GT was register it on the XFX UK site and go through their support ticket system, describing the symptoms and what I'd done (ie remove drivers/drivercleaner/resinstall both 9x.xx and 1xx.xx versions) and after a few interchanges they said it sounded faulty and to return it - which I relayed to Scan the supplier and they promptly issued a RMA without 30 mins of opening on Monday and had a courier round to collect it on Wednesday.
    I am in the fortunate position though of having the old video card to revert to and so am able to continue computing, and to know that I had 7 months of a working system UNTIL that new video card. Unfortunately your 'new build' makes it very hard to know where to point the finger.
    I suggest you try (a) your 7800GT's maker's site/support (b) see if there's a general support forum specialising in that topic (eg I found Bjorn3D.com for XFX graphics cards where I also got help/advice/ideas).
  5. krimson
    krimson What's a Dremel?
    16 Nov 2006
    also, try running tools like memtest to see maybe if you have faulty memory, or try running with just on stick at a time
